Help, my car is dead. Sometime it would start and works for about 15-20 minutes, and then just die. Before the car die., i put the gear in neutral and give throttle, but i just come up to about 5000 rpm and after that it would happen nothing..
Please really need help, no one here in Sweden knows nothing about this car. ( Only 3 nm35 in sweden)
https://www.sau.com.au/forums/topic/444099-my-nm35-is-dead/
A very similar thing happened to me last year, it was AFM.
Is it drivable for those 20 minutes? If so maybe get it to a Nissan dealership if you can and get them to pull the codes or do as PN-Mad suggested and the gurus here will help you out!
Good luck.
https://www.sau.com.au/forums/topic/444099-my-nm35-is-dead/#findComment-7305853
anyone know where i can buy a AFM or if anyone know if it is the same for Another car model?
Since you are in Sweden it could take a long while for one of Scotty's AFMs to get to you. I think some of the Subaru ones are compatible (well good enough if you're not too highly tuned), or Nissan X-Trail.
Search Ebay for 22680-AD201 or 22680-4M500, tone of them should get you out of trouble. Then you may want to investigate buying 10+ from Alibaba ($15-$20 each) so you will have a supply for you & the 2 other M35 owners over there. It will be a common thing from now on....
https://www.sau.com.au/forums/topic/444099-my-nm35-is-dead/#findComment-7306158
