I think people are worried you haven't tuned it properly, as popping usually means lean at wot. Running high boost without a decent tune is crazy obviously. Has it been tuned properly at that boost?
Street racing is looked down upon over here, as we have been brainwashed into thinking babies are killed every time we go 1km over the speed limit.
Yes, we must act our age (40-50), we dont race, we dont line up anyone, both myself and Scotty have lawn bowls hats in the back of our cars and drive super slowly in totaly stock 1.3L push rod Corollas.
We only believe in E85 because we are trying to save the planet. :yes:
Thats funny :D:D:lol::lol::lol:
Man I wont street race no more. Or let you know at least.;) It was popping ant no boost. It has to start moving first aye lol. But it so so great now. I tuned it yesterday at around 12psi. Ill break it in at that pulling 7600 rpms. Sorry but I cant run E85 over here but I do my part on helping out the environment. Like recycle cans and so forth. B)
As for the car the cams seem to work solid. It goes like crazy. Makes me want bigger cams. I was just concerned about my oil pressure. We have no winter over here so I might up the oil to a straight 40 weight full synthetic.
Well got news. I just crashed my gts4 its dead. :(
But the motor is fine so I just ordered a r32 gtr from japan. Just want to say thanks for all the help guys. I wasnt street racing. I got cut off by a ford f150 truck doing a illegal U turn. I guess it happens.
Yes. The oil pan got damaged thats about it. The guy was drinking at a local bar and tried to make a left u turn and took up the whole road. So my natural reaction was to swerve and I lost it went over the the bumps that separates the two lanes and couldn't steer no more and hit another car. The insurance is taking care of it all. And the guy in the truck took off. More than 8 people witnessed the event. Im so disappointed because I spent so much time on this car. I hope when my r32 gtr reach that it might make me feel better... thanks agian for all the help guys really. I have always used this site to learn and be a better skyline technician. R.I.P GTS4.
Edited by MJTru
Thanks guys. After being down for many days I found another car. The car had the engine tear down and never put back together for ten years. It was stored away in a store room for ten years and never touched. Its a r32 gtr so ill just buy a new oil pan and install it. Then ill install the engine. I have a few questions.
1. Is the stock intercooler better than most ebay units like what I used on my gts4?
2. Whats the widest rims can fit a r32 gtr.
3. Any suggestions on the car as it will still be for drag racing.
Stock intercooler is good for over 400Kw
We just bought some 18 X 10.5 +15 and have rolled the guards, ive heard of some people going 11, not sure about how well they would fit without rubbing.
If your drag racing keep the stock wheels and get some M/T Et street rubber on them, if you like aftermarket wheels put something else on for daily street use and throw the M/T on for strip use.
Oil pan is not damaged to bad and ill take photos of it tomorrow. The fins are bent, and im wondering if race fab could repair it. ??
Probably someone local to you could repair it.
Real shame about your GTS4
Would you mind posting up some photos of your gtr with those wheels.
As for the oil pan I was supposed to take some photos which ill do in the morning. I do really like this r32 gtr because its so clean. Its a 100 times cleaner than the gts4. I will be using the gts4 feont and rear diff on the gtr. This is because ive heard that the ratio will be better for drag racing. I really dont know how true this is. But it felt really good when I was driving it.
Edited by MJTru
the M/T et streets will fit on the stock GTR rims...we used 11.5" wide slicks... i'll upload a pic of them when i get home.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
