last Sunday every 2nd month, this time at ACE Karts :)
Can people who couldn't make round 1 participate in round 2?
Ace Karts is an awesome track, although last time I went there 1 of the staff was a complete asshole. Took anyone who spun out off the track straight away. Because you know, it's so hard to spin out in go karts :\
Yes, 100%.
We're working on a points based system for scoring the rounds, based on the results of the very wet round 1, it's still going to be anyones game! (I'm saying this because I came 8th and only got 4 points ;) )
what was your placing?
Ok so points after round 1 are -
Quinton R - 25pts
Sam C - 18pts
John R - 15pts
Ray B - 12pts
Rhys S - 10pts
John P - 8pts
Andrew C - 6pts
Simon H - 4pts
Sean P - 2pts
Tony O - 1pts
Michael K - 0pts
Robyn R - 0pts
I didn't get any points :(
Here at SAU VIC we're an equal opportunity club, we pride ourselves in helping others...
So this might be of use to you Mike, https://www.keys2drive.com.au/learning.aspx
  • Like 1
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
