ABS, is it removable on an R34 GTT without disassembling the whole vehicle, the car is only used on the track and the reason for wanting to remove the ABS is when I need to stop harder than usual the ABS kicks in and the car fails me. Main issues are in Go to Whoa events, unless in casually rolling at the finish line then the car roles past the stop line. The brakes and tyres are more than adequate to pull the car up, but the computer is failing. Thoughts...
Welllllll, you'd need a non-ABS master cylinder, replumb all the brake lines to bypass the ABS system, Nistune the ECU (at the very least) to get around the fault codes and limp mode (and the traction control).
Doesn't sound like you would complete it in a weekend, put it that way.
You could try to pull the ABS fuse, but in R34s the fault codes associated with buggering up the ABS/TCS can cause problems with the ECU putting it into a sort of limp mode. May not happen at stock power levels, but has been seen to occur with engines running some boost.
Edited by GTSBoy
Ok, will try giving it a bash, I run with the TCS off anyways and the ABS well I would prefer that off. Not quite a factory boost either, I'm running 15-16psi most days and it loves it.
Forgive my ignorance.
Abs only kicks in when the wheel sensors pickup a wheel locking.
So you want to stop quicker, and you think you will do so with a locked wheel by going beyond the ABS threshold?
What am i missing? :)
Now i could understand if you were rally driving and wanted to have a wheel lock for weight and balance control reasons.......in those cases you need to be able to have a lock to slide when needed for weight and balance control but your grip driving, not sliding.
Anyone observing your vehicle under braking to see what the tyres are saying from the outside, are your tyres locking and unlocking?
If so look at your brake balance, pad compounds and tyres.
Yeah this, if the front brakes have been upgrade alot more then the back then the front will want to lock and send the ABS skits effectively reducing your braking power
I have just done the 6 piston AP with 355 discs up front and hard braking now sees the ABS activate a lot earlier, am waiting for pipe adapters to fit matching rear 4 pistons :)
What's you setup ?
GTRPSI & XKLABA, I understand exactly where your coming from, from your perspective it would seem as though why would I want to try and brake harder than what seems capable and this is exactly where the answer also lies. It's what seems capable.... But the fact is I know I can brake harder and with more accuracy than what the ABS can, when the rears may be just starting to lock up the fronts still have more in them. I have had this issue on a previous vehicle and by disabling the ABS it could drive harder in the corners, brake later and most importantly brake harder. As for visually inspecting the vehicle while under heavy braking, this hasn't been done as the motorkhana events I have ran it in there were no persons permitted past the start line and none to the sides for safety reasons. As for the brake balance I'm not sure what your mean (brake bias setup)? The pads are Bendix Ultimate pads, callipers are stock 4 & 2 pot that have had a full reco done. Also running factory discs at the moment. In the next 12 months I will hopefully upgrade to AP 6 pots on front and 4 pots on the rear with a set of DBA 3000's or similar.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
