ABS, is it removable on an R34 GTT without disassembling the whole vehicle, the car is only used on the track and the reason for wanting to remove the ABS is when I need to stop harder than usual the ABS kicks in and the car fails me. Main issues are in Go to Whoa events, unless in casually rolling at the finish line then the car roles past the stop line. The brakes and tyres are more than adequate to pull the car up, but the computer is failing. Thoughts...
Welllllll, you'd need a non-ABS master cylinder, replumb all the brake lines to bypass the ABS system, Nistune the ECU (at the very least) to get around the fault codes and limp mode (and the traction control).
Doesn't sound like you would complete it in a weekend, put it that way.
You could try to pull the ABS fuse, but in R34s the fault codes associated with buggering up the ABS/TCS can cause problems with the ECU putting it into a sort of limp mode. May not happen at stock power levels, but has been seen to occur with engines running some boost.
Edited by GTSBoy
Ok, will try giving it a bash, I run with the TCS off anyways and the ABS well I would prefer that off. Not quite a factory boost either, I'm running 15-16psi most days and it loves it.
Forgive my ignorance.
Abs only kicks in when the wheel sensors pickup a wheel locking.
So you want to stop quicker, and you think you will do so with a locked wheel by going beyond the ABS threshold?
What am i missing? :)
Now i could understand if you were rally driving and wanted to have a wheel lock for weight and balance control reasons.......in those cases you need to be able to have a lock to slide when needed for weight and balance control but your grip driving, not sliding.
Anyone observing your vehicle under braking to see what the tyres are saying from the outside, are your tyres locking and unlocking?
If so look at your brake balance, pad compounds and tyres.
Yeah this, if the front brakes have been upgrade alot more then the back then the front will want to lock and send the ABS skits effectively reducing your braking power
I have just done the 6 piston AP with 355 discs up front and hard braking now sees the ABS activate a lot earlier, am waiting for pipe adapters to fit matching rear 4 pistons :)
What's you setup ?
GTRPSI & XKLABA, I understand exactly where your coming from, from your perspective it would seem as though why would I want to try and brake harder than what seems capable and this is exactly where the answer also lies. It's what seems capable.... But the fact is I know I can brake harder and with more accuracy than what the ABS can, when the rears may be just starting to lock up the fronts still have more in them. I have had this issue on a previous vehicle and by disabling the ABS it could drive harder in the corners, brake later and most importantly brake harder. As for visually inspecting the vehicle while under heavy braking, this hasn't been done as the motorkhana events I have ran it in there were no persons permitted past the start line and none to the sides for safety reasons. As for the brake balance I'm not sure what your mean (brake bias setup)? The pads are Bendix Ultimate pads, callipers are stock 4 & 2 pot that have had a full reco done. Also running factory discs at the moment. In the next 12 months I will hopefully upgrade to AP 6 pots on front and 4 pots on the rear with a set of DBA 3000's or similar.
    • $350 for a skid pan day at EC? WTF?? They used to be like <$100? We had track days at EC south and the full circuit for $350-odd WOOOWWWW COVID ruined us all.
    • C'mon Matt, our cars are classics now... *looks at 1kg BigW bottle mounted in front of seat* ah that's been expired for a while now... 😢
    • As above, can't rely on rubber belts too much when you're hitting OVER NINE THOUSAND !!!11!! revs, so electric conversion (Astra as mentioned above) is the way to go.
    • I highly recommend spending a lot of time searching the posts here. There is literally decades worth of information here, and whatever you can think of has been done (besides maybe quad-rotor AWD into a Skyilne chassis). Like, there was someone with an AWD Silvia and a crazy built SR20, and I've personally seen an R31 Skyline (Australian spec) with R32 GT-R running gear (including AWD).
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
