Bogging Down For 3-5 Seconds On Downshifts Only
What you can try is to disconnect the hose with a clamp( or bypass ist with a short tube) . Its under the manifold on the left side . so you can check if it has any effect on the cold start
refering to your cold start Problems this might be interesteing to you https://www.carpassion.com/forum/thema/58441-308-zusatzluftschieber-reparieren-und-einstellen/#comments Problem :you can`t get by without removing Manifold. I Put some Brakecleaner into the Hose to remove the Oildebris, most time the slider is stuck or boken-
brake clearance depends on spoke design GT-R size I'd go 9.5 +15 or +12, and if you've rolled your guards, 10" +20. People run 10.5 but I reckon that's too wide.
By robbo_rb180 · Posted
I was using Realdash App on my entertainment unit in the sil80. Can connect over USB/bluetooth, can set up warnings and is discreet and doesn't stand out bonus was using android auto so had maps and music still going. Put the dollars saved from a screen into decent ecu, sensors and other upgrades.
