Hi guys/girls, I recently went through a box of car parts and came across the factory ecu that came out of my Series 2 Stagea Autech 260rs and noticed the ecu has nismo factory sports resetting stickers on it. I've tried searching the forum here and also google but cant seem to get any decent answers as to what the sports resetting did/changed etc. Can anyone help?
Thanks
The Nismo sports resetting ECU is a factory unit that has been tweaked by Nismo, my mate has an S1 350PS version in his R34.
Basically it removes the speed limiter and raises the boost to 1 bar as far as I know, so a very light tune for a standard car.
Ahh I see. So in saying that would it still increase boost to 1 bar with boost restrictor still fitted?
I take it this wouldn't be a bad option for a car fitted with just a front pipe back 3" exhaust then?
Would there be much point cost and performance gain wise buying something like a power fc or getting a nistune done with only exhaust upgrade?
And does anyone know whether these 'nismo sports reset' ecu's can be nistuned?
Thanks
I wouldn't count on anything with an unknown ecu. If you have limited mods then plug it in on a dyno and see how it goes???
If your planning to plug it into your r34gtr then I wouldn't.
Most of the time you can't nistune a 'tuned' rom ecu from Japan.
I would buy a nistune for your current ecu and have your car tuned by a professional, with your fuel of choice, to suit the intended purpose and climate. You would see some solid gains even with just an exhaust with a decent tune.
Cheers
J.
Fair enough. Yeah I could try that I guess. I just figured all the nismo factory resetting would be the same tune for all of them being apparently only 1 bar of boost as opposed to factory boost pressure. Im guessing that a little extra boost is all you really get with it as the speed limiter removal isn't really a gain. In saying that the boost is increased to 1 bar, why is there so much debate on removal of the boost restrictor being 'risky' considering it increases the boost to roughly 1 bar too so if nismo are happy to do it from the factory as a reset, you would think it cant be too unsafe?
Any idea on what the general cost of a nistune should be?
Not all nismo tunes are the same, you wont know what the timing, fuel or boost parameters are until you try it.
1 bar is normally considered pretty safe on a stock tune... it just wont be ideal in terms of tune.
Nistune is around 400 for the board and 100 for install plus tuning.
Actually, with the RB26 Nissan pretty much always intended it to run 1 bar boost, and the ECU was pretty well mapped for it. The boost restrictor is really only installed from the factory in order to pay lip service to the 280ps gentlemen's agreement that the Jap manufacturers had. That's one reason why the restrictor was marked on the hose with a line - to make it easy to find and remove once the car was bought and no longer subject to the gentlemen's agreement!
Pretty much everything about the RB26 was intended to be a 400 HP engine, including the tune.
The Nismo maps might be slightly different - but I wouldn't be surprised to find that the 1 bar boost on the Nismo cars with that ECU was courtesy of a different (removed) restrictor rather than anything in particular with the tune. And because it was Nismo, and therefore effectively Nissan, I wouldn't be surprised if the ECU was Nistunable. I wouldn't spend money to find out, but it would be a reasonable bet.
Thanks for the posts guys, interesting stuff.
To me it seems that 1 bar boost wouldn't be possible via a 'reset' ecu if the boost restrictor is fitted anyway would it?
One would have thought the 'reset' tunes were all the same from factory as the cars would all have been sold with the same factory setup in regards to exhaust etc unless nismo exhaust systems were a factory option which the ecu's were reset according to if these options were fitted for the buyers.
Any opinions on whether getting a nistune board fitted and a custom tune as opposed to even a used power fc would be more beneficial as I imagine the tuning time and costs wouldn't be much different and ive seen power fc's and hand controllers sell as low as $600/$700
Edited by livewire
If you've got the stock snails run the stock ecu. Pull the boost restrictor out though.
Also these cars are old now, no denying that. Get it checked on a dyno incase the AFR's aren't acceptable or if its knocking. Also get them to set your base timing while you're there.
That way you will know for sure if its safe to run that jap-tune which are often quite knife edge in terms of timing.
Plus you'll get a sweet dyno sheet to show your facebook mates how big your dick is
Thanks for the advice. Yeah. Definitely wouldn't go just chucking a reset ecu in and driving round hoping for the best. Was just wondering whether they were all 'reset' to the same specs and can't quite see how an ecu would adjust boost pressure with the restrictor still in place. Might remove boost restrictor at a workshop and get it put on the dyno and get the shop to try both ecu's and see if they can tell what differences they can pick up in the nismo reset one as opposed to factory untouched one.
My mate's 34 GTR came with the sports resetting ECU which other than that was completely stock. We did some testing and it does indeed run 1 bar with the restrictor in and up to 1.2 with it out.
I'm fairly certain R34s run 0.95 bar standard, my R33 runs 0.85 so 12.5 psi and around 13.5psi respectively.
The sports resetting "S1" unit supposedly is setup for 350ps but which isn't much more than stock but it's something. I'd say with minor mods the benefits increase, there might be some slight mixture or cam adjustments but they would be very minor I imagine.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
