Heya guys,
new to the forum and the skyline series.
I understand that there is a skyline offset thread but i have an exam that i need to study for and can't research.. i also cant sleep until i have a selected offset haha
I am thinking 18x9.5 fronts and 18x10.5 rears.
What offsets would fit my 33? I dont care if i have to run a little camber front and rear, and maybe even flare the rear guards by 15-30mm thats fine.
Any advice and pics would be great.
Thanks in advance.
https://www.sau.com.au/forums/topic/444149-wheel-offset-help-for-r33-gts-t/
Congratulation on the purchase of your new car.
I assume you managed that on your own without a thread spoon feeding you.
Don't be in a rush.
Problem solved.
Edited by Ben C34
+35 offset on 18 inch (235, 45, 18) wheels looks nice on skylines. The offset on most skylines is usually for brembo clearance though... Thats the only reason you'd actually worry about offset... the brake clearance. Not sure if they rub the guards or not on the GTST or GTS. Also camber = useless if you dont track your car, you will just end up with un-even wear man. But yea probs +40 max on 18s to be on the safe side (provided it isnt a GTR).
ooo And also, these guys do know a bloody f*** load about cars, they have a lot of experiences, wheels isnt really worth a discussion unless the situation is something unique, hence their responses :P Have a look through the forum, you will see very technical questions, things i dont even understand, and they answer it bloody well and true. But yea hope i helped you though, congrats on the car :)
Edited by Deza3000
Nope. Offset doesn't determine brake clearance, spoke design does. Standard turbo Nissan wheels from the 90s are 6.5"+40. GT-R's are +30.
If the wheels are a non-dish style (e.g. Driftek) then the lower offset is an indicator that it has good brake clearance (because the spokes would concave in more). You will have to look at the wheel backspace, it differs depending on manufactures (e.g. Rays wheels have heaps off room, compared to say a BBS knockoff).
Offset determines where the wheel sits relative to the mounting surface.
  • Like 1
Oh my mistake it does too! I just realized my spare tyre has a offset of +45 or something, but a bulgy convex spoke design for brake clearance, looks kinda retarded. Ive just always used offset to determine brake clearance haha. Then again i never buy deep dish wheels.
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
