Ok I tried to search this but none of the search buttons work for the rb20det page. what is the diff between td05 16 18 and 20g and what is the performance difference on a rb20 compared to rb25 series 1 turbo.only driven on street will have 440cc and nistune.cheers
https://www.sau.com.au/forums/topic/444168-td05-16-18-20g-rb20det/
The inducer size of the compressor impeller is what changes. As you go up from 16-18-20, the compressor basically gets a bigger gulp capacity. Check for a few comments posted by Lithium regarding the TDO5-16G6, similar/same spec as an Evo.
Be aware that there are different TDO5 turbine rotors.
Hardsteppa has played with a TDO5-18G on a RB25 with I believe decent results.
Potentially good units at an affordable price, you can lean on them a lot harder than an aging OEM Hitachi unit off an RB25.
Have played with a couple of RB20s with TD05H-16Gs - actual Mitsi ones, on RB20DETs and give the stock RB25 a SERIOUS run for it's money in terms of response but definitely suited to more power, and generally better suited to the RB20 really. They definitely work very well on them, depends on how much power you are after etc.
It's old news in the Mitsy world but Hi Flowing their TD05 16Gs with the 18 and 20G versions of that compressor family tends to make them increasingly laggy .
If you search you could find out which Mitsubishi turbos had 18 and 20G compressors standard - turbine wise .
In Evo terms Mitsy went to a lot of trouble to make the engine package work and up to Evo 9 never used larger compressors as original equipment . They actually went slightly smaller in couple of models to make them spool earlier , think one version was called 15GK2 in the TME E6s .
Long short the 16G6 compressor is a good match for the TD05 turbine and makes for a balanced turbocharger wheel size wise .
A .
Depending on the rest of the setup I think a Kando 16G would be awesome on an RB20 - though I think on stock manifolds, cams and pump gas you'd be doing well to hit 260rwkw (depending on the dyno) regardless of which of those turbos you chose. I am not as familiar with RB20s and what they like to make with given mods so not 100% sure on what to expect there, but I tend to think of them as needing a bit of work to get up to around 260rwkw. I wouldn't count on that power from a 16G but I do think it would be an awesome drive, if what a 16G makes isn't enough then I'd step up to a 20G - personally... not sold on the 18Gs being a worth while in between.
You are aiming at the internally gated one, I assume? We have been playing with the idea of going with a bigger map sensor and trying to see if we can max out a Kando 16G on ethanol at some point - will update the Kando thread if we do.
If you are going internally gated the Kandos tend to need some porting on the wastegate as well. As much as I'm not a fan of Stao going into threads about other turbo types and pushing is product, I actually suspect one of the Hypergear turbos might be a better option for the power level and setup you are looking at - if 260kw (or more) is your target. If you are looking at mid/low 200kw and you aren't afraid to do some porting, or have someone who can port the wastegate whole to closer match the flapper then the 16G would be a total winner.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
