-5 (for now)
E85
Built engine
Street use only
I have tomei type b's ATM, and yes they will suit better for that setup, bit they idle a limitless mellow for my liking
If I pull fuel/timing at idle, this will give the idle I'm after?
Again, will 272/264 idle different to 272/272?
Ive been trying to know if my hks 272 cams will work for my drag setup. Im running a built motor and its for only drag racing but it seems like people are using the title "DRAG" as an excuse to answer if it will work or not. Im planning on running 10000rpms off the line. Will this be enough??? No one ever answered me in detail.
I wouldnt do this build for just the sound but I would choose to do it for that gain I would have according to the propose of the car. Which is only for drag racing max hp at WOT, and not for how it sounds at idle. Here is some photos of my setup. Oh the damper will be changed out thats just a mock up one. Details please guys
Edited by MJTru
Well I didnt really port it out. I just cleaned up the factory matching marks. I also took the hunp out tge exhaust ports. I have spring and retainers and valve to work with the cams. But ive always been asking for help with the cams. But obe one seems to want to help in deatail. Guess in the future ill just have to pay for the help. But I have already plan on swapping them out for oem one. I have lots of experience with those. Ill post photos of the ports
Marcus, you are in the wrong thread.
And, yes, if you are planning 10k rpm and drag racing then yes you DO HAVE THE RIGHT CAMS (although as zebra points out you might even need more). We've already covered that.
OP, you have problems. If you want that idle, the cut one of your coil wires.
Edited by GTSBoy
  • Like 1
well...you have given us nothing to go on
272 is the advertised duration
what is the duration at 0.050"?
what lift?
The motor has the factory intake...so not exactly designed around 10,000rpm
are the springs good enough for 10,000rpm?
are the springs good enough for 10,000rpm with a bucket load of boost being shoved down its throat?
Damn I deleted the photos out my phone. But im after velocity thats why I never ooened up the ports. But choosed to just clean it up. What im doing is not a 100% drag as you woukd see the top end guys do it. I just street drag race. And as for the lift is close to stock lift. But I do know its 272 duration. Whicj is weird. I got these cams with the motor and couldn't finf the lift so I mesured them and its about 8.8 mm lift.
Sorry if im in posting in the wrong place. GTSBoy. But it seems like when I was trying to find out everyone was away on vacation. I realy dont care to brake things learning. But by no means enjoy it this is why I try to learn by asking. I have never really build a full out race car in my class. As I do agree just doing it for the sound is insane. As for the intake not designed for 10k I can swallow that and im willing to change that. But isnt this forced induction and what and how much woukd the intake really matter. Please explain in detail and help not just me ecmveryone for that matter out. Our intuition will lead the way after that. As for the valve train I have listed part numbers of the springs and retainers as welm as asking if they will be adequate for my set up. Everyone was on vacation. What do you mean when you say. "Whats the duration at 0.050" im lost. How do I measure this. Cause I hate not know and understanding the setup. I shoukd just burn this car down before I even flipping try 10k.
Shit I was saying the same thing long time ago. But I kept getting "its drag racing of course it will work." I build around and knowing its not a real all out drag car. Its just what I intend to do with the car. Thats all. I dont even race the car on a real drag strip with track bite, all I do is illegal street drag racing to me its more fun. Kml. I will take those cams and put them up on display as for sticking them up my ass. Lol. Hell no. Lol. Do anyone want to buy hks 272 at 8.8mm lift. Lol
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
