Hey guys,
Just hoping everyone can keep an eye out for my 1999 s2 stagea (number plate: YRX 436) that was stolen tonight (08/07/2014 between 8:30pm and 10pm) outside a mate's place a Glen Iris, Victoria.
It's pearl white with black r33 wheels.
If you see it, please contact the police or me on 0422 897 384.
Thanks.
https://www.sau.com.au/forums/topic/444179-stolen-stagea/
Hey guys,
I recently bought the car from a guy on this forum back in April.
Link of the ad:
http://www.skylinesaustralia.com/forums/topic/439137-fsft-1999-x-four-stagea-9000-ono/
However, since owning the car, i have added a tow bar, removing the stickers on the boot lid glass and swapping the rims to stock r33 rims that were spray painted black.
Cheers
https://www.sau.com.au/forums/topic/444179-stolen-stagea/#findComment-7308996
There are a few gutter rashes on the rims, heaps of scratches on the front bumper and rips in the roof lining.
Will also need the ignition and door locks replaced.
Car smells like alcohol and smokes too.
Like I said, grateful for it to be back home.
  • Like 1
https://www.sau.com.au/forums/topic/444179-stolen-stagea/#findComment-7309901
Glad to see you have it back!
https://www.sau.com.au/forums/topic/444179-stolen-stagea/#findComment-7309922
No doubt they flogged the guts out of it.
Oil change, filter, brake pads, gear oil etc etc.
What a pain, and ill bet it never feels the same again.
I know my old 32 was stolen at some point in its life, The ignition barrel was stuffed.
3 years of fking around with new bushes, bearings, this and that. Its getting better now.
:/ Hope yours gets better soon.
Oh... and underneath, mine is hammered, so much the chassis is a bit off.
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/444179-stolen-stagea/#findComment-7309928
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
