I know that the number of older Japanese performance cars on the road in Japan would be fairly low now, but do people generally have a lot of respect for the older cars? I'd assume that the older guys do, but what about the younger generations?
And what older cars do they have a lot of respect for? (aside from the obvious Hakosukas', S30s and KPCs)
https://www.sau.com.au/forums/topic/44418-oldskool/
Nostalgic Hero rated 25 of the best for their 100th Volume edition.
Some I agree some I don't...and some where left out :)
1. KPCG10 Skyline HT2000 GT-R
2. S30 Fairlady Z-L
3. KPGC110 Skyline HT2000 GT-R
4. MF10-C 2000GT
5. KP510 Bluebird 1600SSS Coupe
6. AS285 Honda S600
7. K111 Subaru 360DX
8. E-DR30 Skyline Sedan 2000 Turbo Intercooler RS
9. UP15 Toyota Sports S800
10. KHGC211XFT Skyline HT2000 Turbo GT-E X
11. TE27 Corrola Levin
12. TA22-MQXR Celica 1600GTV
13. L10B Cosmo Sports
14. PA95 Isuzu 117 Coupe 1800
15. PR91W Bellet 1600GT-R
16. SR311 Fairlady 2000
17. B110 Sunny Coupe 1200 GX5
18. N360 Honda N360 Touring S
19. 41D-2 Gloria Super 6
20. S124A Savanna GT
21. S130JTB Fairlady 2000 Turbo Z-T 2 Seater
22. A-KHC130 Laurel HT 2000 SGX-E
23. S54B-2 Skyline 2000 GT-B
24. PD-100 Contessa 1300 DX
25. A53CGR Galant GTO MR
https://www.sau.com.au/forums/topic/44418-oldskool/#findComment-908327
Basically they got their sbscribers to vote for their favourite, and its the order of most popular classic japanese car to least. And that's the top 25 of that list.
Nostalgic Hero is like "the" classic car collectors magazine in Japan.
https://www.sau.com.au/forums/topic/44418-oldskool/#findComment-908351
DR30 doesnt, and 211 Turbo barely does
I think the Galant GTO isnt much older either if its the one I'm thinking of
But yeah, most are 60's/early 70's
Galant GTO MR is 1970.
As I said there are some I agree, some I don't and some which got left out. One I have to admit is the '80s DR30, I can't believe it is in there...it ain't nostalgic enough to mix with those in the list. Yes most are 60s and 70s.
As for the voting, I'm not sure as I was only interested in the read itself. Many of the owner's who had their car featured basically kept the car in the family when their old man bought the car....the 2000GT was increadible...immaculately kept to this day.
V8Skylineman: 211 is in there.
https://www.sau.com.au/forums/topic/44418-oldskool/#findComment-911493
Ah k, I thought it was the boxy early 80's Lancer
Yeah, DR30 does seem quite out of place, they still feel reasonably modern to drive (well... mine is much nicer than the near new Lancer I drove to other night) and don't really have a nice flowing shape (actually from some angles I think the proportions are awful)
Still, its nice to see it in there, shows I bought something that still gets respect with all the other classic Japanese cars
https://www.sau.com.au/forums/topic/44418-oldskool/#findComment-912328
Adam, I think you were thinking of the A-175A Lancer, I actually want one of those...they are 1980s. They could have been considered for the list above given it's Rally victory success in the 80s. I did see one but was snatched up really quick, has the early 4G32 motor and 4wd running gear...you can guess what I need the shell for a sleeper.
GTSR22, you should learn to spell? 2000GT is a very car, love them too. Very sought after car in any collectors garage and demands more than a KPGC10.
https://www.sau.com.au/forums/topic/44418-oldskool/#findComment-913558
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
