Anyone familiar with the modification road rules?
Here's my project. Taking R33 GTS S1 rims off and replacing with Advan's 18" x 265, they obviously won't fit so thinking of either putting JUN flares on or fibreglass replacement quarter panels. Legally how wide can I modify the car on WA roads? I'm willing to add yet another permit to the collection if need be.
https://www.sau.com.au/forums/topic/44419-legally-how-wide-on-wa-roads/
iv got some info from the "department planing & infrastructure"
a summary is;
-Rim width must not exceed the maximum rim width specified by the manufacturer by more than 25mm. (thats taken from your tyre placard)
-In any event, rim width shall not exceed 7'' unless specified by manufacturer as standard equipment for the vehicle in question.
-No increase in rim width is permitted for vehicals fitted with the original equipment rims in excess of 7'' width
-the wheel is contained completely within the bodywork of the vehicle which inclueds acceptable flares.
so most people that get mags can be yellow stickered as most mags are wider than 7.25" that inclueds me.
Sorry no pix but standard JUN S15 flares http://www.junauto.co.jp/products/aero-par...-fender.html?en
Rims and rubber are 18" x 265 x 35, I suspect the rim's offset could be why they stick out out of the standard guards and don't mind cutting away but just trying to do the right thing and do my homework, I already get enough attention with a carbon fibre bonnet (yes and it has a permit).
Thanx RBVS, may be worth my while paying them a visit and just clarify it with them.
Should'nt be too hard to make a new placard that includes larger rim/tyre sizes.
Yea i thought of that, getting a placard from a car that has 9'' wheels stock but, they'd prob know off hand without looking at the placard that there too wide, givn they ve prob delt with a skyline befor.
hmm interesting
my 18's should be here this week 8's on the front and 9's on the back
I was told by the wheel place that 265's will fit on the back (so i got them)
You can buy flares for ya r33 from UAS (Unique AutoSports)(nismo.com.au) for like $95 each corner... looks alright too
Damn these laws about the wheel sizes and zorst db limits etc
No wouldn't be too hard.....as long as you owned Nissan or Toyota.
RBVS
Faking a plate would place you in hot water with the authorities too unfortunately.
The track of any vehicle cannot be increased by more than 25mm legally.
Plus on GTS Skylines as the rim sizes were same front to back you cannot run wider rims on the rear. Think the police don't pursue that one fortunately.
Cheers
r34 - if you're fitting a widebody kit you're not widening the track (the wheelbase) but just the car itself. maby check the adr rules for the max width of a car body - not wheelbase?
Cam
The track and wheelbase are two different things(correct me if I'm wrong)
Track is the width with wheelbase being the distance between front and rear axles I believe
The car would look a bit silly if you fitted a wide body kit and left the wheels stock.
I thought that the reason for fitting was to fit larger offset wheels.
Wide bodys with large offset wheels look cool but the authorities don't allow a track increase more than 25mm to prevent stress on balljoints/suspension generally.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
