Hi all,
Had a bit of a garage clean up so I have the following items for sale.
Sard 800cc Injectors x 6
Top feed, Low Imp, Removed from GTR (RB26)
No problems, injectors were only removed due to upgrading to E85.
Price: $400
Bosch 044 Fuel Pump
Same as injectors, working condition - only removed for upgrade to E85.
Price: $70
Trust Sump Extenstion - RB26
Sump extenstion already welded onto sump/diff, no baffles/pickup or diff - bare sump only.
Sump plug is stripped, has a dodgy helacoil currently - shouldn't be to hard to tap a new thread.
Price: $220
Cusco Strut Brace - Suit R33 (Front)
Price: $70
Roof Spoiler - Suit R32
Fibreglass, purchased from Viva Garage many moons ago.
Price: $70
M-Spec Overflow Tank
Suit R33??
Price: $30
S13 SR20 Crossmember
Price: $40
S13 SR20 Standard Sump
Price: $20
S13 Lower Control Arms
Will need ball joints replaced.
Price: $30
PM or MSG 0422 Four Six Six 118
Thanks,
Damon
https://www.sau.com.au/forums/topic/444208-rb26-performance-parts-misc-s1xr3x/
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
