Hi,
i will be fitting a set of tomei type B poncams (260deg 9.15mm) to my rb25det neo soon, but im having a hard time finding suitable valve springs. Can anybody tell me if the standard valve springs are single or duel springs? will i need to change valve spring guides if i go from single to duel or vise versa?
Also what is the general consensus on reusing retainers, collets and cam hold down bolts?
  • 8 months later...
In the same boat as you. Have been told that the neo head can handle 22psi on pump fuel and 25 26 on e85. But if wanting to run more than 22psi I need to upgrade the spings. Have been told by a few people to stay away from profamance spings and go for supertech spings. Been having problems finding them tho.
why not just see how it goes on the dyno? pretty sure a lot of people have had no issues without even opening the motor..
worst case scenario is they start to valve bounce and you have to change them then a touch up tune??????
Edited by AngryRB
with the tomei type b's you run the risk of spitting a shim with standard springs. they wont float or do anything bad its just one of the things that CAN happen.
Tomei do a matching valve spring but Jap springs are rubbish.
Ring places like supertech about a spring to suit 25neo which is a shim over bucket (not shim under bucket like rb26) single spring with something like 64 pound seat pressure (least i think its 64 pound but that was a bulldog spring for some serious ramp rate cams so might be a bit overkill for you.
how do the springs know what psi is being given?
The pressure applied by boost to the back of the inlet valve is how they know. The more boost the more pressure trying to open the valve.
So running 20 psi adds 20 psi of opposing force to the spring being able to close the inlet valve.
As Mark says PSI is irrelevant - revs, power and cam profile will determine the need for new springs.
Just to add to my previous post, power makes no difference to valve spring requirements.
How does the valve know how much power its making?
Revs, cam profile and boost are basically the factors.
Notice how engines valve float but when boost is reduced can still rev cleanly to redline? The valve opens and shuts just the same when at max revs regardless of power output, the difference is how much boost acting against the inlet valve closing.
I ended up getting 'performance' springs, haven't installed them yet tho.. Isn't a big name brand but haven't heard anything bad about them plus aussie made so should be sufficient.
Because I have to travel ~ 2000km return to a tuner, why not do it right the first time
PSI is VERY relevant.
I can't see how power can make any difference seeing that both valves are shut when it goes "bang".
Boost pushing against the intake valve is a big contributing factor in float.
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
