R32 GTS-T 4 DOOR
NSW Rego Till December, Located South West SYDNEY
SPECS:
Dyno Tuned At Chequered Tuning in Melbourne, 240KW ATW (4500 RPM Boost Threshold)
Gtr front bumper and grill, lip
RB20DET (Rebuilt/Forged Bits)
Poncams
GT3071r (0.84 rear housing, braided oil lines)
600CC injectors
Splitfire coilpacks
Z32 AFM
Nistune
Clutch Replaced Recently
Oil temp pressure, water temp, boost gauges,
Driftworx Front Coilovers, Rear KYB Shocks/Lowered Springs (Works very well, comfy)
Engineered To Slide Knuckle Setup
Adjustable castor Arms
Camber arms
Toe arms
Braided Brake Lines
Poly Diff Mounts and Brace
Cradle Slip ON Collars
All around hicas lock bar,
R32 Type M Front and Rear (4/2 piston)
Slotted rotors
Relatively new pads,
Drift Button handbrake, tight
Shimmed LSD
Kakimoto Regu 96r exhaust, Modified turbo manifold and Dump pipes (3+ inch all through)
FMIC (Sprayed Black)
3 Inch Piping
Stock Airbox & POD (Running POD and blocked stock BOV ATM)
Redone Shifter Bushing
Nardi deep dish wheel
Black Racing N1 8/9" wheels
Michelin Sport tyres front, Zetum sport rear (225/235)
DMAX spoiler
JVC Double Din Head Unit, 6x9's Rear.
R32 GTR Nismo Pump
Immobilser
Car was brought into Sydney from Melbourne about 6 months ago, car fully complied with blueslip requirements and is fully legal, other than ride height being a little low.
Does not attract any unwanted attention. Especially nothing from police.
CHEAPER INSURANCE
Body has a few dings, marks, scratches here and there. Front bonnet has rain marring, front bumper installation is a bit patchy. It's a 1989 skyline imported, you know what to expect.
Car has other rough bits here and there from over the years, i.e. rear doors hard to open, power windows a little slow, small panel cracks and imperfections.
Leak oil, probably rocker cover as rb20's do
Car runs well, reliably, pulls well.
SWAPS or $9k ono
https://www.sau.com.au/forums/topic/444231-nswsw-sydney-r32-4-door/
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
