Rb26 Compression With Poncams Type-B
Yep same as last few posts. Last step before pulling the engine back out again is mineral oil and provided everything is feeling half ok I'd give it heaps. Heaps of boost and heaps of load. You need to try and undo all the glazing of the bores that idling will have done. Hopefully there is enough cross hatch (you did hone the bores I'm hoping???) to bed the rings in a bit better. As per above you need to force the rings hard out against the bores hence why you want plenty of boost or load to achueve that.
Good luck, it's a bitch to have to pull the engine out again if it's no good!
This /\ /\
When I built my engine I comp tested at +/- 150psi before starting it, started it and let it run for 5mins, dumped oil refilled with mineral diesel oil, took it out to the M4 did some controlled loading till I got to the mountains then vaired from 3500rpm to 4500rpm as it climbed the hill came back down turned around and did a couple of 2nd gear hill starts at 4000-5500rpm, went home dumped oil and refilled then comp tested at +/- 170psi, a year later it comp tested at the same +/-170psi
Which will increase overlap and drop compression.
Why are you worried?
I don't understand why the cams were adjusted, says on the RHDjapan website that they are a drop in cam which
don't need adjustment and if adjusted 1degree will dramatically impact idle and low end torque.
If it affects idle then that means compression test will be crap.
Maybe set the cams to normal position and retest?
Edited by AngryRB
Desperate measures for bedding in rings on an engine that had been accidentally glazed up after a rebuild used to be to tip a tablespoonful of Bon Ami down the carby. I shit you not. Slightly harsh treatment to be sure, but given that it is either that or take it apart and re-hone with new rings......
You could rig the AFM up to a hose onto the TB to bypass the turbo if you were needing to do it to an RBDET.
drop in means they fit without head mod (shimming doesn't count here). How does Tomei know what the user wants out of his setup?
My point was, the maker of the cams suggests that changing the timing of there cams will affect idle and low end
torque, extra duration creates poor combustion efficiency at low rpm, so at 200rpm it would loose a lot of compression on a test if OP has increased the Overlap.
http://www.rhdjapan.com/tomei-camshafts-poncam-rb26dett.html
Edited by AngryRB
mine is currently +2 intake -4 exhaust
100 psi is very low, what exactly did you change when doing the rebuild, are the cams timed correctly
Those setting should actually increase the compression reading, even if it is only a little bit as they aren't that big of a change
You need to lean into the motor gradually and stay away from any synthetic oil for the first few thousand Km.
Load the engine, you need pressure to push the rings onto the bore to bed them, idling does nothing but take the peaks off the hone without bedding in the rings.
I recon go back to a mineral oil and lay into it a bit, hopefully most of the cross hatch should still be there.
Also check your mixtures, if your running rich, expect to see your oil contaminated with petrol, its not a good thing to wash the oil off with fuel on the bores, not a good start to the engines life.
 Share
    • That is typical (for a rb at least) with a medium to large turbo, noting the format of the graph is probably misleading what you see a little (half portrait width but full height, in landscape it would look quite different) Basically until it hits target boost the torque curve is rising steeply, when that is 4000+ rpm it is not great to drive since almost all of your life is between 1,000 and 3,000 rpm. Once you hit target boost the wastegate opens and torque stops rising so quickly. From there the shape of the curve depends mostly on the cams and where they have a peak vs the rev limiter
    • Last of the maintenance items for now....not sure why but the drivers side window switch had heaps of wear on the right front and right rear switches Unfortunately, unlike earlier Skylines the controls are bolted to the door trim from the inside. So....off the with door trim. There are bolts or screws: Behind the door handle cover, pop it off from the handle side Under the rubber trim at the bottom of the door pull (also just pops up) Behind the courtesy light at the bottom. Other than that, just window down then pop off the usual selection of push in clips around the perimeter and the trim lifts up Interesting that they have a bolt on cover instead of the old school plastic held on by goop....I guess they prioritised sound levels over price Then, 2 screws and 2 plugs to replace the switch (looks identical to the Fuga/Q70 one incidentally) and put it all back together. Also much better
    • ok I understand, but the majority of turbo vehicles lose torque, or have a flat torque curve after the spool.  hence my initial misunderstanding. I didn't think this type of curve was possible
    • It is completely normal. Your original understanding is what was wrong, not what you see in the charts.
    • made with turbo and tuned by (hypergear)
