Hey everyone, new to the forum just trying to gather some information regarding what you are running ignition timing wise..
First off, here my current setup...
S2 Rb25det
Garret 3076r (.64)
Tial 38mm wastegate (mv series) wastegate is set to .75 bar
standard 370cc injectors
standard pump
Im running a haltech r32/33 platinum pro plug in play and i'm having some issues with knock...
If any of you have experience with the knock control could you tell me what your peramiters are?
What are your ignition tables like? what kind of ignition are you running through peak torque?
My injector duty cycle is getting to about 65% at .75 bar when i can get there but i'm hitting knock retard. My AFR's are constantly monitered and logged and i havnt been leaning out, but im unsure of how the standard pump fair's with that many more CFM coming from the bigger turbo.
I am not hitting a full knock ( knock light ) but am getting up to 6-7 * timing pulled around 160kpa 4000ish rpm.
If someone could screen shot me their ignition table i would much appreciate it.
Thanks in advance,
Connor
https://www.sau.com.au/forums/topic/444287-rb25-non-neo-ignition-timing/
Why are you wasting your time with a stock pump and injectors with that turbo? They will hold you back.
Spend the money on a pump and injectors and get it dyno tuned before you kill the engine.
As i mentioned, the Duty cycle of the injectors is only reaching about 65%, and my air fuel ratios are quite within check. I am going to be running ID 1000's and im hoping to get away with a single 255lph pump.
I am simply looking for someones ignition map to reference to my own, I need to take the car across a body of water and about 200km inland of where i currently am and i'd like to have a safe tune to drive there with it.
One piece of information i have gotten through your reply is that you think stock pump will hold me back immediately. thank you.
It's extremely likely your stock pump will fail as they are getting on and it's not worth risking an engine by using an an old pump.
A walbro 255 will fit in easily and are cheap as.
PM Scottynm35 on here for a price.
What sort of timimg are you running?
How are you monitoring knock?
Correct me if I am wrong anybody here with more knowledge. But I am thinking that at .75 bar on a 3076 would be needing to use more than a 65% duty cycle on the stock injectors?
Otherwise, definitely replace the stock pump before doing anything more. They are incredibly prone to failure or dangerously poor flow on R33's by now. Many a failing or failed stock fuel pump have killed an R33. This may be your problem atm.
Yuh, I'm having trouble understanding how you could be only running 65% duty cycle on standard injectors when you have a big turbo running more than stock boost.
The factory injectors should run out of puff by 220 rwkW, which is a sneeze for a GT3076. And it should be even lower than that when running the original fuel pump.
thanks for the replies, I have a walbro ordered through my local supplier, ( I am in Canada by the way) and just received pricing on my id 1000's.
As for knock I am using the OEM knock sensors running through my haltech plug and play. I need to try and contact someone out there with the same ecu and try and figure out what their settings are for the knock control as mine is registering knock in area's where its pretty much impossible ( not full knock but it is starting to retard timing ) This area on the haltech is not as user friendly as most others.... The ignition map is VERY safe atm and im currently just daily driving the car to make sure it is all sound mechanically after the work i did with the turbo setup.
The knock sensors i believe are being triggered by my external opening aswell as other random noise factors and the knock control is set up very conservatively (safe motor <3 )
I don't have plans to dyno it until my injectors and pump are in. I appreciate the advice guys and clarification of my original thoughts.. really appreciate it
Well, relying on the original knock sensors is probably your problem. They can give false knock readings very easily. The only solution here is to strap on some good knock detection equipment (either a good set of ears or a good knock monitor) and see if it really is knocking.
great line :yes:
Final thought for the OP. Are you sure that your ignition timing is set correctly on the motor vs what you are intending on the Haltech?
Edited by jjman
first thing is first.. have you set your base timing exactly at 15 degrees using the CAS?
You can lock the timing with the Haltech so there's no need to adjust the idle, disconnect the TPS, etc.. like the stock ECU..
  1. Load up the Haltech Software
  2. Press F4 - this takes you to the Main Menu
  3. Go to BASIC --> Ignition Tab
  4. Go to Ignition Lock, and choose Enable
  5. Perform normal CAS adjustment till timing is at 15
  6. Disable the ignition lock
There's no way in hell the stock Haltech map will knock with just 0.8bar of boost.. the timing is very safe.. the only reason it would if your base timing is off OR something is going on with your AFRs
Okay, now this has kind of confused me,... i set the timing in haltech to 15* and timed the cas at the crank markings to 15* , am i supposed to read what the ecu is telling me for ignition? or go off the crank...
The engine is runing 15* timing. the computers ignition lock entry is 15*
okay, make sure you turn off the ignition lock once you've checked the timing marks
however, makes no sense why it should knock with the haltech factory map.. the timing values are very safe.. unless you've got 1+ lean cylinders due to faulty injectors etc..
pull out your spark plugs and see if they're all consistent
Keep in mind it might not be knocking for real at all.
of course, better not discount that idea.. the factory sensors aren't that great
do you have access to a standalone knock monitor such as a K-Mon or Phormula KS kit?
I was looking at the Phormula kits, well priced. Are they as good as the Kmon? Anyone used one?
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
