  On 11/06/2014 at 10:48 PM, scotty nm35 said:
I was looking at the Phormula kits, well priced. Are they as good as the Kmon? Anyone used one?
I've used the K Mon before (in someone else's car) - not that user friendly.. however not the Phormula Kits.. they do look sexy!
nice little unit I must say!
http://www.phormula.co.uk/Player.aspx?clip=KS3-Settings&title=Settings%20-%20KS-3%20Knock%20Analyser
  On 11/06/2014 at 11:06 PM, Badgaz said:
I've been looking at those as well... There are some good YouTube demonstrations of it.
You guys interested in buying it together to save on shipping? I could potentially see if they're willing to do it cheaper if we get 3x and we do reviews on the unit(s) on SAU and also my personal site trak-life.com
  On 12/06/2014 at 12:08 AM, Lithium said:
Yeah, hence "if you are serious" ;) I make do with a G4 Knock Block
hahaha probably will never be that serious, although I've had a few SR20DET boys recently with basic bolt-ons asking for road tunes. I have another one next weekend going on E85, I've already swapped the injectors & pump and touched up his tune to accommodate the new squirters - might hire a dyno again for this one.
I think the Phomula KS-3 will be more than enough for my needs (mainly 98RON), I find E85 doesn't really knock unless you really fuark up the timing.. usually you know timing is at its peak when the car makes no power when you add more timing in.. then again, I'm relying on the factory knock sensors and the aftermarket ECU to pump out some arbitrary knock value which could mean absolutely nothing as others have told me.
Yep. Ask away. I have Paypal funds burning a hole in my hard drive. :)
KS-3 OR KS-4?
KS-4 has outputs so you can setup closed loop ignition feedback on certain ECUs to retard timing on knock OR whatever your heart pleases
  On 12/06/2014 at 2:19 AM, Badgaz said:
actually...no.... ks-pro kit. the ks-4 doesn't have headphone output.
looks like we need 5 kits, but we get 15% off and free delivery!!!
Thanks for your email.
If you can get more than 5 units sold, I’ll authorise a 15% discount and offer free shipping to a single address in Australia. If you have anyone interested in other products or accessories we can extend the discount across those too. Hopefully that keeps things nice and simple.
KS-4 RRP £295… Group Buy £250.75.
KS-3 RRP £235… Group Buy £199.75.
Please let me know if you need any further information and I’d be glad to help.
Best Regards,
Anthony
right... So ive pretty much fixed it. I Reset CAS timing with the haltech, The cas WAS at 10* for some reason while the ecu thought it was 15*. .. anywho they are in sync now. no more knock issues..
Also installed a Walbro 255, Car runs very well now, still running some pretty light timing (15-16* or so at peak torque) great afr's all the way to redline (6500 currently) but im ALMOST out of injectors. like 90% duty cycle. so thats definitely coming soon.
Just to add add to what I wrote.
On the previous page op said he is using the oem knock sensors.
To me that's a fail.
And is unsure of the correct settings, and even mentioned he was registering knock when it wouldn't really be possible.
He then advanced the timing 5 degrees and it fixed it.
This is not a thread about how useful knock detection is.
It is is a thread about how having things you don't understand can actually make things more difficult for you.
Go get your car tuned op! And let us us know.
Ah yes, I just skim read it and assumed he had it too far advanced,hence the knock, but it is indicating 5 degrees retarded isn't it,
OP, you are reading the timing marks correctly aren't you? Also using the correct technique to read the timing?. (I.e. not on the cold start map and also using cyl no 1 lead and not the 'timing wire')
I didnt fix the "knock" by advancing timing, as mentioned in a previous post about setting up the haltech with the cas ( using ignition lock and making the computer and engine insync) it was off by 5* I retimed the car using a better timing light 15* in the ecu was 10* in reality. ( all i know for sure is that the computer didnt actually know what the hell was happening)
Ben, it seems when you come to your own conclusion it gives you the right to be a jerk, I'm really not about the internet tough guy so if you feel like you have to be that way don't bother posting on my thread, thanks.
BTW, the car never saw harsh driving and full knock situations. I was how ever getting ignition retard to a degree because the knock sensor calibration was very high. Im not an idiot and i know what will and what will not blow up a motor.
I was at the dyno on friday with a friends rb25 s13 running a Sprint 500 and his timing is at 20* through peak range with NO knock. I am running around 4-5* retarded of what he is running with LESS boost.
JJman, the car has now been timed properly and is running exceptionally well. Next step is to install injectors and start dyno tuning.
Thanks for all your POSTIVE imput guys, much appreciated.
Edited by ConnorOrcherton
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 😢, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 🤔
