I was looking at the Phormula kits, well priced. Are they as good as the Kmon? Anyone used one?
I've used the K Mon before (in someone else's car) - not that user friendly.. however not the Phormula Kits.. they do look sexy!
nice little unit I must say!
http://www.phormula.co.uk/Player.aspx?clip=KS3-Settings&title=Settings%20-%20KS-3%20Knock%20Analyser
I've been looking at those as well... There are some good YouTube demonstrations of it.
You guys interested in buying it together to save on shipping? I could potentially see if they're willing to do it cheaper if we get 3x and we do reviews on the unit(s) on SAU and also my personal site trak-life.com
Yeah, hence "if you are serious" ;) I make do with a G4 Knock Block
hahaha probably will never be that serious, although I've had a few SR20DET boys recently with basic bolt-ons asking for road tunes. I have another one next weekend going on E85, I've already swapped the injectors & pump and touched up his tune to accommodate the new squirters - might hire a dyno again for this one.
I think the Phomula KS-3 will be more than enough for my needs (mainly 98RON), I find E85 doesn't really knock unless you really fuark up the timing.. usually you know timing is at its peak when the car makes no power when you add more timing in.. then again, I'm relying on the factory knock sensors and the aftermarket ECU to pump out some arbitrary knock value which could mean absolutely nothing as others have told me.
Yep. Ask away. I have Paypal funds burning a hole in my hard drive. :)
KS-3 OR KS-4?
KS-4 has outputs so you can setup closed loop ignition feedback on certain ECUs to retard timing on knock OR whatever your heart pleases
actually...no.... ks-pro kit. the ks-4 doesn't have headphone output.
looks like we need 5 kits, but we get 15% off and free delivery!!!
Thanks for your email.
If you can get more than 5 units sold, I’ll authorise a 15% discount and offer free shipping to a single address in Australia. If you have anyone interested in other products or accessories we can extend the discount across those too. Hopefully that keeps things nice and simple.
KS-4 RRP £295… Group Buy £250.75.
KS-3 RRP £235… Group Buy £199.75.
Please let me know if you need any further information and I’d be glad to help.
Best Regards,
Anthony
right... So ive pretty much fixed it. I Reset CAS timing with the haltech, The cas WAS at 10* for some reason while the ecu thought it was 15*. .. anywho they are in sync now. no more knock issues..
Also installed a Walbro 255, Car runs very well now, still running some pretty light timing (15-16* or so at peak torque) great afr's all the way to redline (6500 currently) but im ALMOST out of injectors. like 90% duty cycle. so thats definitely coming soon.
Just to add add to what I wrote.
On the previous page op said he is using the oem knock sensors.
To me that's a fail.
And is unsure of the correct settings, and even mentioned he was registering knock when it wouldn't really be possible.
He then advanced the timing 5 degrees and it fixed it.
This is not a thread about how useful knock detection is.
It is is a thread about how having things you don't understand can actually make things more difficult for you.
Go get your car tuned op! And let us us know.
Ah yes, I just skim read it and assumed he had it too far advanced,hence the knock, but it is indicating 5 degrees retarded isn't it,
OP, you are reading the timing marks correctly aren't you? Also using the correct technique to read the timing?. (I.e. not on the cold start map and also using cyl no 1 lead and not the 'timing wire')
I didnt fix the "knock" by advancing timing, as mentioned in a previous post about setting up the haltech with the cas ( using ignition lock and making the computer and engine insync) it was off by 5* I retimed the car using a better timing light 15* in the ecu was 10* in reality. ( all i know for sure is that the computer didnt actually know what the hell was happening)
Ben, it seems when you come to your own conclusion it gives you the right to be a jerk, I'm really not about the internet tough guy so if you feel like you have to be that way don't bother posting on my thread, thanks.
BTW, the car never saw harsh driving and full knock situations. I was how ever getting ignition retard to a degree because the knock sensor calibration was very high. Im not an idiot and i know what will and what will not blow up a motor.
I was at the dyno on friday with a friends rb25 s13 running a Sprint 500 and his timing is at 20* through peak range with NO knock. I am running around 4-5* retarded of what he is running with LESS boost.
JJman, the car has now been timed properly and is running exceptionally well. Next step is to install injectors and start dyno tuning.
Thanks for all your POSTIVE imput guys, much appreciated.
Edited by ConnorOrcherton
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
