Hi mate, when i still had my V36 I had issues with the windows after I replaced a battery.
Give this a shot, it might work for you as well:
* put the ignition to "ON"
* push the buttons down to open the windows & hold this for about 5 seconds after the windows wind all the way down
* push the window buttons up to close the windows & keep holding the buttons for about 5 seconds after the windows wind all the way up
After I did this my windows worked fine for me.
Let me know how you go
Got too excited, just tried and now it works!! you're a legend!!
Did u had any issues with Slip, BA, ABS lights coming on the dash? do u have a fix for this aswell??
Brake fluid levels is ok, brakes has been bleed fine
You are a legend!!! :cheers:
And I don't mean a dodgy old mans Honda... :yes:
all good, happy to help. :)
For the record I'm not 100% sure if the method I use is the proper handbook method, I just went from memory on a trick a service manager showed me on a 2006 350z when I was working in car sales, but hey it works ahaha
I didn't have issues with my dash lights coming on... try resetting the ecu & see if that works
Mine was clicking the door central locking for no apparent reason after charging the battery up. It was clicking like pretty constantly but not actually locking or unlocking the door. Really weird. Anyway i disconnected the main drivers window control with the central locking button removed the circuit board and sprayed it with contact cleaner its been fine since.... Anybody know anything about this?
It was deff that circuit board as with it disconnected it stopped straight away. I could still lock and unlock the car with the key fob.
hmm i have this problem too but it doesnt work for me :( it goes down automatically but have to hold up to bring the window up. plus my window drops when the door is open. hmm
  • 5 years later...
  • 1 year later...
  • 11 months later...
Just an FYI, and to bump this for others. I had 2 problems with my passenger side electric window on my 2008 370HT
1. When I closed the door with the window up, it would actually leave the window open about 2 centimetres. I had to manually go over to the drivers side, and wind the window up/closed.
2. When I held the up for the passenger window (drivers side or passenger side control), the auto wind up did not function.
I found another thread on another site, and it suggested the same as above, but 10 seconds hold when down, winding up and holding while its at the highest for 10 seconds. I did these steps, and now both problems are resolved.:91_thumbsup:
  • Like 1
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
