It's obviously the piston's fault, not the clearance. :P
Get on to your machinist/engine builder and ask him exactly what Piggaz asked above. My guess is he set it up loose because you want to lean on it hard, hence you will get a bit of noise.
very common for forged pistons, p2w ( piston to wall clearance ) will vary depending on the load / heat the engine will endure , Since forged piston expand with heat (more then stock) some builder will run a higher piston to wall clearance then recommended by the MFG so the piston will not hit the cyl wall when it will expand a bit more depending on the load / heat. This is what you call piston slap. It will quiet down as your car gets to operating temperature because of the expansion of the piston with the heat.
If the noise persists when hot, now that would be another issue.
I would like to know if you have the build sheet or could ask your engine builder what piston to wall clearance he is using for your aplication
Well the apparently hks gave pre cut rings for the 2.8 stroker kit.. I wanna hear from hks piston owners lol
I like the way you haven't answered how much piston to bore clearance you are running.
And aren't all piston rings "pre-cut"? They would be pretty hard to get on the pistons otherwise. Gap can only be adjusted by removing material!
So ask your machinist.....he set it up.
If you want to quieten it down you could always get new bigger pistons and rings and rebore/hone it correctly or friction coat the piston skirts which takes up a little clearance.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
