  • Replies 52
Rb30's need a few small modifications first eg needs oil lines tapped into the block for the turbo, I'm also not sure how strong the crank would be on an rb30 to handle 300rkw.
Machining costs mite be expensive as their is more work needed.
I'm current getting my Rb25det machined with arias forged pistons, rb26 rods and keeping the crank standard. Its costing me heaps, buy the time you but all parts and put it all back in, it becomes a motor reliable motor, and should have no probs handling the power out put your after, If tuned well. But if you have the money to put an rb30 bottom end in I would recommend it as their are good benefits. But to make the motor reliable and strong you would have to spend a lots more all round to make that happen.
That depends what RB30 block you get. SII block has all the provisions for the turbo.
Apart from that the only other modifications required depends on what cam belt you use.
Its a little off topic but just to compare how tough the RB rods are:
Here's a little snip from a bloke i'm exchanging pvt messages with.
He's got a RB26 with a GT40 thats almost done.
My brothers is running 300rwkw at the moment and is only using stock rods, and I'm pretty sure it would be able to handle 350rwkw, just excessive revs may decrease their life span dramatically.
Hopefully we will be aiming for near 400 so we will be able to work out what is going to go first in a standard (although brand new and balanced) bottom end.
Generally most workshops will start upgrading the rods once they near 400rwkw. Although PSI03L has been running shotpeened standards for a while (nearly 2 years) and that has been running in excess of 500rwhp.
Hopefully my rods handle 300rwkw maybe just a little more with no problems. :(
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
