  • Replies 52
Rb30's need a few small modifications first eg needs oil lines tapped into the block for the turbo, I'm also not sure how strong the crank would be on an rb30 to handle 300rkw.
Machining costs mite be expensive as their is more work needed.
I'm current getting my Rb25det machined with arias forged pistons, rb26 rods and keeping the crank standard. Its costing me heaps, buy the time you but all parts and put it all back in, it becomes a motor reliable motor, and should have no probs handling the power out put your after, If tuned well. But if you have the money to put an rb30 bottom end in I would recommend it as their are good benefits. But to make the motor reliable and strong you would have to spend a lots more all round to make that happen.
That depends what RB30 block you get. SII block has all the provisions for the turbo.
Apart from that the only other modifications required depends on what cam belt you use.
Its a little off topic but just to compare how tough the RB rods are:
Here's a little snip from a bloke i'm exchanging pvt messages with.
He's got a RB26 with a GT40 thats almost done.
My brothers is running 300rwkw at the moment and is only using stock rods, and I'm pretty sure it would be able to handle 350rwkw, just excessive revs may decrease their life span dramatically.
Hopefully we will be aiming for near 400 so we will be able to work out what is going to go first in a standard (although brand new and balanced) bottom end.
Generally most workshops will start upgrading the rods once they near 400rwkw. Although PSI03L has been running shotpeened standards for a while (nearly 2 years) and that has been running in excess of 500rwhp.
Hopefully my rods handle 300rwkw maybe just a little more with no problems. :(
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
