Hi all,
Just wondering which wideband oxygen sensor to get. First thing is what are peoples thoughts on running an O2 gauge? I don't particularly want to but I spose it would be good to monitor AFR's. This car will be doing lots of drifting and I was hoping to just run oil temp, pressure and water temp.
Will be using an Adaptronic select plug in R34-GTT ECU.
Would ideally like to run something from the tech edge catalogue because they are Australian. All I really need is a sensor to feed wideband AFR's to the ECU.
https://www.sau.com.au/forums/topic/444361-wideband-o2-sensor/
Having a gauge is a personal preference thing. Personally I look at it after doing any work in the engine bay but if you're hammering it around the track you won't so much as glance at it
edit: I'd have to agree with the MTX-L. I couldn't get the serial output working on my AEM EUGO but with a mates MTX-L it never had an issue. (same PC)
Edited by Blackkers
Email adaptronic for the gauge, there is one that can be wired into the ecu and give you real life reading on both the gauge and loges with the ECU. I've got that on my Kia, works very well and very handy when comes to road touch ups.
yeah that would be the Innovate MTX-L lol
http://www.adaptronic.com.au/product/mtx-l-wideband-airfuel-ratio-gauge/
If you're not really fussed about the gauge, how does the LC-1 compare against MTX-L? Have heard reports about it being "hard to wire up" but I'm not sure if that's a legitimate complaint. Some people shouldn't be let loose near a soldering iron :P
There is an LC-2 newly released but adaptronic not carrying it yet.
I had a brand new AEM UEGO that was reading about .6-.8 more rich than at the tailpipe after comparing 2 other widebands.
The only difference is that the permanent sensor is installed pre-cat obviously. Not sure if that's normal
Both or one of them might be due for a free air calibration?
Agreee with that. My LC1 seemed to read great. Had a 10% difference with the sensor used on a dyno.. trusted the dyno sensor and ended up maxxing out 555cc Nismo Injectors with not enough power to match.
Ditched the Dyno and operator when he was "going for the 300kw" regardless of the rich detonation, and took over 10% fuel out from 3500rpm and above on the road on the way home. Turned out the LC1 was spot on.
I just made sure i re calibrated it each Oil change. 3+ years now.
I got 4 years out of mine on ethanol, but it wasn't the sensor that went, it was the LC1 unit that failed.
It is carbon that buggers the sensors, especially if the heater can't keep up with cleaning it off. I know tuners that replace the sensor every week or two as they cop a hiding from running rich on petrol.
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
