Hey guys doing a manual conversion on my r32 rb20det. Put the gearbox in and used an s13 crossmember. However when i put the tailshaft on and bolted the centre to the car it (picture 1) seemed to have a gap on the tranny end? Secondly, in the second picture the shifter hole doesn't line up to the centre, is this normal? Cheers for any help.
Shifter is normal. The auto tunnel opening is in a different place than the manual one. The manual boot and all fits on, but tends to put a little pressure backwards on the shifter. I've never had trouble with this on mine after.....I dunno, 13 years?
With the tailshaft gap - be aware that the gearbox is supposed to have a pressed metal (and cad plated) cup pushed into the extension housing that would cover that gap.
Provided that's the one that came with the manual tranny, that's the one that I said puts backward pressure onto the shifter. I can't remember if I made it work better by turning it 180° or not. Might be worth a look.
Again, I can't remember if the auto one fits on the manual shifter. Too long ago.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
