Hi I just started my car and I notice after about 15 minutes of idle a red light came on right under the oil presaure gauge its tye same gauge but there is a light right under the zero mark. Is this a oil temp light???
Also what Canada cause the oil temp to het so hot at idle. I have a grex oil cooler with thermostate build inside. When I feel tye actual oil cooler its not hot but warm. The oil filter is a bit hotter than the oil cooler core.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/
What do you call hot? Do you have an oil temp gauge? The oil cooler is set to open at about 86degC but it is never completely closed allowing a small amount of flow so that would account for the oil cooler radiator being somewhat warm. BTW why are you idling your car for 15 minutes? That light could be an oil pressure warning light - what pressure does it show after 15 minutes of idling?
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311101
Hmm. I just left the car to cool down for about an hour. Now tye red light is off. Im at it right now and will uodate again soon. Tye gts4 doesnt come with an oil temp gauage like the gtrs. I think. I dont see one
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311104
What does the oil pressure gauge run at idle and whilst running at say 3000rpm
I don't believe it is Oil Temp light it is an Oil pressure failure light.
1. Perhaps oil pressure sender or oil pressure sensor failure
2. or the biggie a serious oil pressure issue
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311129
Also when was the last time you serviced the car ?
Maybe worthwhile dropping and replacing the oil and oil filter.
Even run a quality engine flush through it whilst changing the oil/filter.
Edit: Just read some of your other topics
Looks like your building an engine with your clearance questions, after market sump and aftermarket cams
All bets are off on the info I've posted above :/
Edited by Sinista32
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311137
IF it is indeed a recently built engine with an extended sump.
Check the oil pick-up/scavenging as it may have dropped off.
something blocked somewhere between sump, pump, filter
crank, bearings, collar, pump, etc... such a big list
or simple like the sensor
released air from the oil cooler ?
I got NFI
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311169
Thanks for all the info guys. But I had the car running and the light isnt coming on anymore. Its a fresh build. What stumped me was at idle around 850rpms the oil pressure was at half way on the gauge and the light was on. I cut the car off and restart it. It was still on butbtye gauge went to half. This is why I thought it had nothing to do with pressure and thought it might have been a temp light. Makes sense now that it the zero oil pressure light. I wounder what happened. Cause its not coming on anymore and how can it come on and the gauge was at half way mark. I think half way mark is 4.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311221
I didnt release the air from the oil cooler tho. I pulled the cas sensor and crank the motor with no spark plugs in it to receive drag on the starter. So I crank the motor off and on untill oil was in the cooler. Then I started it up.
Edited by MJTru
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311225
Since it happened I've been keeping an eye on tye oil pressure gauge religiously. But tye light never came back on. I haven't driven tye car as yet. But will be very copious about it. Im overhauling my front suspension before I take it for a drive but ive been lettingbthe motor idle every day on and of. For the first day it smoked a little but now I notice its stopped smoking tye light blue smoke. I believe that the light blue smoke is oil. I guess the oil rings are now worn in. Or seated. I didnt bore the block because it was in great shape.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7311929
Um........this is a new engine right? Idling and new engines are baaaaad.. Mmkay?
What you mean GTSBoy idling a new engine is bad. Hmmm. Im lost Mmkay. Kml:lol: Edited by MJTru
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7312608
I just finished looking it up. I guess its time for light loads at different speeds. So I wont start it anymore. I need to drive it and induce a vacume to seat the rings. Thanks for the indirect explanation.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7312611
You need to drive it harder, and get some boost pressure under the ring to force it into the cross hatch hard. That way it will file the rings down and bed them in well, making a good ring seal. Usually done on the dyno.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7312714
Thats where i differ, i drove ours easy for the first 3000klms and we have little to no blowby at 25psi of boost from a 6766. Makes near 500rwkw and is a beast of an engine. I know people who drove them hard and ended up with shit boxes that had nothing but issues. I guess every one is different
MJTru, if i were you i would be getting a quality aftermarket oil pressure gauge and hooking it up to check the oil pressure. Just pull the standard switch out and put the gauge in there. The standard gauge is ok for knowing when something major fails but for a fresh engine to be setting off lights like this i think i would be checking it further to confirm 100% there are no issues.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7314731
Perhaps they were shitbox engines when they were machined, which is the most important part after all. Surely you had your car tuned before that 3000k though Brad?
My stock 200,000k engine has little to no blowby, and I have been thrashing buggery out of it for years... What does that mean?
OP, The standard gauges are crap and known to fail. If you are trusting in them you are mad. Get some decent aftermarket gauges in there, and if you don't like a dash full of dials like me there are plenty of other options. I went with the Informeter Touch.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7314777
Doubtful as they all came out of the same workshop, built by the same person. Machined by the same shop using the same techniques. The only difference i can think of is that we run GReddy pistons and rings, the rest ran CP's. Who knows
Our car was tuned prior to the rebuild. Its been in the car for damn, 9 years almost now and still going strong. I was going to put head studs in it but not going to bother until the government figures out what will happen with ethanol based fuels and the cleaner fuels grants. Not much use if ethanol will be dead in Australia because they pull the funding
Edited by ido09s
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7314967
Mate I agree with you. Run it hard kml. Like where does that idea come from. But I do agree in the whole theory of the process of braking in the motor. I do believe that today's technology can produce a motor that you can just beat off the bat or run hard, But caution is the prevention for cure. Lol. Its funny cause all you mentioned I did already. The aftermarket gauge and all. As well as the oil temperature gauge. Please dont get me wrong guys I thank all of you for you invaluable opinions. This mentality is what makes this site so strong. The motor sounds strong and I cant wait for my radiator aftermarket radiator to reach and drive the car.
I will keep everyone posted.
https://www.sau.com.au/forums/topic/444377-rb26-in-gts4/#findComment-7315049
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
