As much as a nistune can be fitted it is a mission into a R34, their is a thread all about doing it if you search for it ( OP, not Ben I know he knows all about it :D )
I would use the PFC for a street GTR that doesnt want Flex Fuel any day, the only problem with the PFC is as much as most every tuner can tune them, very few know how to do it properly/fully, I have a PFC in my R32 and have done so for 7 years and it drives better then it ever did with a stock computer, though it didn't when it was first fitted and tuned but then I found Scott and it has been brilliant ever since and given how fast my 32 is given its power output proves it
My 34 had a PFC in it when I bought it and it drove quiet well then I let Scott at it and again became perfect to drive and if it supported Flex Fuel it would most likely still be in there
This is my opinion, blast me all you like for it it won't change what I have seen for my self and how I feel about it, I like the PFCs and when tuned properly do exactly as they are asked with no fuss
Depends what you want to do, or how far you want to go.
Does a normal power FC have launch control, antilag, ability to run on a MAP sensor, spark cut RPM limiter and the ability to simply add extra devices through expansion ports. (not talking Jetro or Pro series Power FC)
None of which should be needed on a normal street tune GTR....but needed if your getting serious or you have $ tied into your engine.
We went with the Haltech Platinum Pro because it opens a range of future possibilities, even something as simple as the race dash pays for its self, no need for expensive gauges and mounting, warning high low limits can be set on a wide variety of things your monitoring or worried about.
Having said all that, Power FC covers what most people need day to day, good thing is they are getting cheap because newer ECU's which are in demand like the Haltech, i wouldn't hesitate to run a Power FC on a mildly worked daily driver.
  • 1 month later...
15+yo PFC or a brand new, current tech haltch that's been designed/built/developed in Aus and is very flexible?
as for just the tuning? better resolution, more options to offset timing and fuel trim etc. Same same for any competent tuner to 'use' or 'tune'.
The one thing that I would have liked in my PS2000 was knock correction, but the plug in (my pick for your application) does have knock correction.
J.
  • 3 weeks later...
  • 1 month later...
My motor rb30/26 + t78 turbo
Wat difference will I see when using haltech platinum pro compare to power fc ?
Thx
Hope the RB30/26 setup you have with the T78 works better than my T78 worked for me on the street, it was a pig to drive as a DD and did nothing until 5000rpm
I had a worked Rb26 motor, forged pistons etc. From what was said to me, it is hard to get the T78 to come on full boost before 5000rpm, mine was later , at about 5500-6000 for full boost and rip your head off.
Maybe it was the tune, I am new to this but everything I have read so far indicated that they get full boost no earlier than 5k with an RB26 motor.
I put a PT6262 and poncams B and it was a different car tuned by the same bloke??
Maybe everyone has a different idea of lag, but mine was SO LAGGY and with the quad clutch a sh@t to drive, full load and steep hill take off, it was hell on wheels.
I do not mean doing a 6-8000rpm launch, maybe the clutch had a lot to do with it???????
Sorry off topic
  • 4 weeks later...
i owned a PFC with -5s and now changed to a Haltech with a HKS T51r yes both different turbo setups but changing from the PFC to Haltech everything seems alot smoother with the Haltech!
i do agree with the above every tuner pretty much knows how to tune Power FC but i also agree with XRATED they are designed, newer technology and you have everything there ready to go if you decide to change for a track setup or E85 or Flex tune. it also allows you to use alot of add ons as also mentions above. but to that is double the price of the PFC but, i found the PFC to feel very strange when it was cold, i cant quite describe the feelling but you can definatly notice the difference with the 2. as for a tuning perspective i dont know which one is "nicer" to tune, but thats for your tuner to work out. also choose a computer your tuner feels most comfortable to tune,
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
