This is a copy paste from my build thread so I'll add details up top for those who don't know the car.
CA18, 4 piston fronts, slotted/vented front rotors, slotted solid rears, QFM A1RM pads, BM50 Master, new fluid, standard lines, non ABS, all calipers recently rebuilt and system fully bled with 2 people, brake duct vents.
Only the caliper rebuild , master rod adjustment, fluid, and brake duct vents are new, everything else I already had before the caliper rebuild and worked fine.
I can't figure out why the pedal feels stiff.
I noticed on the last track day that the pedal felt quite firm (runs were only 45 or so secs so not enough time to warm brakes) The car would still stop and I could lock up the brakes if I pushed hard enough but it felt like I had to push fairly hard and that there wasn't a lot of progression in the pedal, as in only a small amount of travel (but lots of force) was required.
I've pulled the front wheels and there's plenty of meat on the pads and no obvious issues with calipers/rotors.
I've test the booster by pumping the pedal a few times and holding it then starting the car and the pedal dropped down a bit as vacuum builds so I "think" it's fine. I also adjusted the brake master rod to the pedal after rebuilding all the calipers.
I'm thinking one of two things.
1) It's stiff because they are such hard pads and need a lot of heat in them, though I don't remember it being "this" stiff when I did this brake upgrade originally.
2) During the bleed process I've pushed too hard and the master is shagged, though I'd of thought it'd leak? (It's a BM50).
Thoughts? I can just wing it at the next track day which is a proper circuit day so will be able to get the pads hot, but don't want to risk damaging something or having brake issues at speed.
  • Replies 46
Removed 1 way valve, tested, can't fault it but I doubt my mouth can pull the same vacuum as the engine. (Even after all my years working the corner).
I've pulled the booster out (shit job) and cannot "see" anything wrong with it, but I have not disassembled it yet (need to review my Nissan manual).
What am I looking for once I pull it apart?
And you can't disassemble a booster. That needs special tools. I got the one on my car rebuilt....actually that may have been on my ALFA, about 15 years ago. I just took it to ABS (I think, although it might have been Power Brakes in Norwood). I'm sure there's an equivalent in Melbourne....not so much up at the river though
Spoke to brake guy and he said he's almost certain it will be that those pads have hardened/are too hard but gave me some more booster tests to do, connect to vac on the car and then I should be able to move the rod by hand, if not it's dead, if so it's fine.
If it tests fine I'll put it all back together and see what happens when I get the pads fully hot at Winton in a few weeks.
Annoying because removing the booster was a shit job and putting it back will be worse. Probably shouldn't have jumped the gun in removing it...
Just rip the lot out and put in an adjustable pedal box.
"Hmm where can I get one of those?" you say
I'm glad you asked
http://www.skylinesaustralia.com/forums/topic/443943-brand-new-obp-adjustable-pedal-box-assembly/
Doubt it's the pads. I have the same on my 32, they were used for a few months then sat for 2 years and still work fine (have been used at track a number of times since).
Also they don't require much heat in them to work to their full potential either, I have never noticed any difference between first and last hot lap.
On a side note, I have noticed they aren't a very 'progressive' pad, they bite reasonably hard with little pedal effort.
As others suggested I'd look elsewhere. Good luck with it, interested to know the outcome.
I have another set I can try but the car isn't registered and it's too wet to get it out.
I've done some more booster testing and it seems fine so what else does that leave?
If it had a seized caliper you'd think it would pull to one side or brake unevenly and it didn't.
I think his point was that I'd cooked the pads and that they're cactus.
I did get to a point a few times at the last Winton day where I'd over heated the brakes and had to back off, which is why I added the brake ducts.
I had to machine the rotors back so much that there's no slots in the fronts anymore. Just above minimum thickness.
If you can post some photos of the pads someone might be able to tell you if they're cooked.
But also when you overheated the brakes it could have been that you burnt the fluid, did you bleed them in between sessions and check the colour? This doesn't explain why you've got the stiff pedal all the time but just making the point that it may still not be the pads.
However if you've got a spare set of pads you may as well try them.
What would you suggest then? As I said I'd expect the car to drive poorly if a caliper was seized so that leaves me with the master being stuffed, and though it's not leaking internally that's not to say the diaphragm isn't stuffed from being pumped during bleeding.
I'd really love to avoid having to bleed the bloody thing again.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
