Fitted R33 booster, pedal sink on startup is more pronounced and there seems to be a bit more travel on the pedal (i measured everything too so it shouldn't be in the booster rod adjustments).
Won't now til I drive it but weather is looking really uncertain so not sure if we'll make the test and tune on Friday or not. If we do go I'll take the other set of pads also.
  • Replies 46
Like GTSBoy said. The booster is the problem or vacume leak. The adjustments will change the travel of the pedal. Please stay in touch as ill do my best to help. If your running big cams which will lead to less vacume?? Can also lead to this problem. If thats the case you will need to run a vacume canister. ??
