Just wondering if anyone has had dealings with classic performance dyno centre in hackam? Saw a lightening yellow c34 with sign writing. As im a stagea owner and looking at getting some work done in the near future (coupled with the whole bright yellow thing) caught my eye.. I usually only use places that are recommended to me and im pretty new to the Nissan (or any modern car really) scene and new to adelaide, im not in the know.. any feedback appreciated :)
Cheers
https://www.sau.com.au/forums/topic/444414-advice-on-workshop/
I haven't used them so i cannot comment but i too am looking for someone in the coming months to do a heap of work on my M35 Stagea.
At this stage i am very tempted to drive interstate as there are tried and tested workshops who have worked on M35's.
R&D Mechanical in Seaford is another option to check out tho mate. I have not used them either but i believe their tow car was a C34 Stagea...
Cheers
A few mates have used him for tunes with great results and were very happy with his work. Even with dialogistics over the phone with nistune issues he was able to help out.
Speak to elir32 he uses him and would recommend his work to anyone.
My car will need to be tuned sometime during the end of the year and im looking at giving the keys to him,
Some handy info. I liked they had a 4wd dyno at least.. I have a squeaky something under the bonnet, maybe the waterpump..some sort of bearing noise at least.. may as well put a new timing belt on too. These adelaide roads will make certain a suspension replacement sooner than usual..jeeze :P
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
