Looking for offers around 24k negotiable.
2000 JDM Import 1JZ-VVTI S15
I'm looking at swapping to an Evo X for a more 'work suitable' car.
Since I've owned this car, I've funnelled a lot of money into it to make it the best possible street/daily car. It's incredibly torquey and fun & easy to drive.
Conversion was done by previous owner however I've spent a lot of time under this car, and the quality of the conversion is damned good. My Mechanic has carried out 1JZ swaps before, and couldn't fault the work done.
Car is modplated for the engine & gearbox conversion, road registered and fresh 6 months rego put on 4 days ago.
Chassis has 123,000ks on it and is perfectly straight.
Engine
Engine is stock, and comes on boost immediately. Cruising on the highway in 5th gear, if you touch the loud pedal more than 10% you're on boost.
Car was dyno'd by last owner at 265RWHP, but it's the torque that feels amazing. The VVTI 1JZ improved both fuel economy, and a 20% increase to low down torque.
Motor & Gearbox has 111,000ks on it, and had new HKS timing belt and major service at time of conversion (previous owner)
Oil and filter changed 1000km ago (Penrite 10W40 Racing Oil & Ryco Z418 Oil Filter)
Koyo Radiator & twin thermos - New Radiator hose installed last week 23/05/14
R154 5 speed Gearbox, Custom lightweight tailshaft to stock R200 diff
Brand new OS Giken Grand Tourer Twin plate clutch w/ hard metal front cover (custom made by OS Giken and took 3 months to get from Japan), rated to 700hp, incredibly quiet for a twin plate and super easy to daily drive,
converted from Push type clutch to Pull - This is a $2300 clutch and the best you can buy.
OS Giken lightweight flywheel & new high tensile flywheel bolts
New Spigot Bearing and Rear Main Oil seal installed at same time.
Penrite 75W90 Gearbox Oil
3" custom exhaust with highflow cat (one of the most beautiful sounding cars I've driven)
Turbosmart Boost Tee - only running 1 bar. Standard Turbo can run 18PSI reliably and standard 1JZ internals are good to 600-700hp.
Upgraded Front Mount Intercooler (unsure of brand but it's about as big as you can fit under the front bar)
Exterior
18x9.5 +20 Rota Dished wheels, 245/40/18 tyres all around
Guards rolled - no scrubbing
New front and rear tridon wiper blades ($100)
Stock Body Kit
Stock JDM Rear Wing
OEM White Paint in good condition. 1 small stone chip on bonnet. May have been resprayed by previous owner.
Interior
Brand new TRD short shifter & shift knob, imported from Japan - Cost $350
Custom Black painted interior (over stock interior's easily scratched silver) - Sound/heat proofed the trim at the same time
Defi Boost Gauge (previous owners - not sure if geniune)
Defi Water temp gauge (previous owners - not sure if geniune)
Viper Alarm System (LED Pager that alerts you when something goes on with the car up to 1 mile away) - Blue flashing light with sensors on windscreen says "Don't even think about trying to steal this car" - Alarm is freaking loud.
Real Carbon Fiber Centre Console (Gearstick & Radio Surround) - Cost $200
Suspension
SPL Titanium Pro Caster/Tension Rods ($300)
Blitz 32 way adjustable coilovers
Also have (not currently installed)
Dakota Digital Tachometer adjuster ($180 from the states) (common issue when swapping to a bigger engine and keeping stock dash, tachometer is out by 1/2, this is a plug and play item that adjusts it to the correct RPM)
Brand new in box Nismo 280k speedo ready to install ($350 from Japan)
Custom black leather & red stitching shift boot, arm rest cover and handbrake boot ($60 imported from UK)
Nismo strengthened clutch pedal bracket ($90 from Japan)
I have receipts and logs for everything I've spent on this car.
Comes with RWC
post-115107-0-43741500-1402799001_thumb.jpgpost-115107-0-30161200-1402799004_thumb.jpgpost-115107-0-86347500-1402798999_thumb.jpgpost-115107-0-32226100-1402799193_thumb.jpgpost-115107-0-43171800-1402799213_thumb.jpgpost-115107-0-51571200-1402799307_thumb.jpgpost-115107-0-49792600-1402799308_thumb.jpg
https://www.sau.com.au/forums/topic/444429-jdm-s15-1jz-gte-vvti/
Wiper blades and arms :) But I agree, I thought it was a bit excessive at the time!
It was kinda an urgent thing, It was tipping it down leaving work and I couldn't see a thing, I commute a fair way and just wanted something quality. Having said that they're by far the best I've used (No screetching, jumping or leaving lines). As far as wiper blades go they look pretty good too.
Ordering them online I could have maybe saved $20 or so, but the situation didn't allow :)
Bump for offers.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
