Looking for offers around 24k negotiable.
2000 JDM Import 1JZ-VVTI S15
I'm looking at swapping to an Evo X for a more 'work suitable' car.
Since I've owned this car, I've funnelled a lot of money into it to make it the best possible street/daily car. It's incredibly torquey and fun & easy to drive.
Conversion was done by previous owner however I've spent a lot of time under this car, and the quality of the conversion is damned good. My Mechanic has carried out 1JZ swaps before, and couldn't fault the work done.
Car is modplated for the engine & gearbox conversion, road registered and fresh 6 months rego put on 4 days ago.
Chassis has 123,000ks on it and is perfectly straight.
Engine
Engine is stock, and comes on boost immediately. Cruising on the highway in 5th gear, if you touch the loud pedal more than 10% you're on boost.
Car was dyno'd by last owner at 265RWHP, but it's the torque that feels amazing. The VVTI 1JZ improved both fuel economy, and a 20% increase to low down torque.
Motor & Gearbox has 111,000ks on it, and had new HKS timing belt and major service at time of conversion (previous owner)
Oil and filter changed 1000km ago (Penrite 10W40 Racing Oil & Ryco Z418 Oil Filter)
Koyo Radiator & twin thermos - New Radiator hose installed last week 23/05/14
R154 5 speed Gearbox, Custom lightweight tailshaft to stock R200 diff
Brand new OS Giken Grand Tourer Twin plate clutch w/ hard metal front cover (custom made by OS Giken and took 3 months to get from Japan), rated to 700hp, incredibly quiet for a twin plate and super easy to daily drive,
converted from Push type clutch to Pull - This is a $2300 clutch and the best you can buy.
OS Giken lightweight flywheel & new high tensile flywheel bolts
New Spigot Bearing and Rear Main Oil seal installed at same time.
Penrite 75W90 Gearbox Oil
3" custom exhaust with highflow cat (one of the most beautiful sounding cars I've driven)
Turbosmart Boost Tee - only running 1 bar. Standard Turbo can run 18PSI reliably and standard 1JZ internals are good to 600-700hp.
Upgraded Front Mount Intercooler (unsure of brand but it's about as big as you can fit under the front bar)
Exterior
18x9.5 +20 Rota Dished wheels, 245/40/18 tyres all around
Guards rolled - no scrubbing
New front and rear tridon wiper blades ($100)
Stock Body Kit
Stock JDM Rear Wing
OEM White Paint in good condition. 1 small stone chip on bonnet. May have been resprayed by previous owner.
Interior
Brand new TRD short shifter & shift knob, imported from Japan - Cost $350
Custom Black painted interior (over stock interior's easily scratched silver) - Sound/heat proofed the trim at the same time
Defi Boost Gauge (previous owners - not sure if geniune)
Defi Water temp gauge (previous owners - not sure if geniune)
Viper Alarm System (LED Pager that alerts you when something goes on with the car up to 1 mile away) - Blue flashing light with sensors on windscreen says "Don't even think about trying to steal this car" - Alarm is freaking loud.
Real Carbon Fiber Centre Console (Gearstick & Radio Surround) - Cost $200
Suspension
SPL Titanium Pro Caster/Tension Rods ($300)
Blitz 32 way adjustable coilovers
Also have (not currently installed)
Dakota Digital Tachometer adjuster ($180 from the states) (common issue when swapping to a bigger engine and keeping stock dash, tachometer is out by 1/2, this is a plug and play item that adjusts it to the correct RPM)
Brand new in box Nismo 280k speedo ready to install ($350 from Japan)
Custom black leather & red stitching shift boot, arm rest cover and handbrake boot ($60 imported from UK)
Nismo strengthened clutch pedal bracket ($90 from Japan)
I have receipts and logs for everything I've spent on this car.
Comes with RWC
post-115107-0-43741500-1402799001_thumb.jpgpost-115107-0-30161200-1402799004_thumb.jpgpost-115107-0-86347500-1402798999_thumb.jpgpost-115107-0-32226100-1402799193_thumb.jpgpost-115107-0-43171800-1402799213_thumb.jpgpost-115107-0-51571200-1402799307_thumb.jpgpost-115107-0-49792600-1402799308_thumb.jpg
https://www.sau.com.au/forums/topic/444429-jdm-s15-1jz-gte-vvti/
Wiper blades and arms :) But I agree, I thought it was a bit excessive at the time!
It was kinda an urgent thing, It was tipping it down leaving work and I couldn't see a thing, I commute a fair way and just wanted something quality. Having said that they're by far the best I've used (No screetching, jumping or leaving lines). As far as wiper blades go they look pretty good too.
Ordering them online I could have maybe saved $20 or so, but the situation didn't allow :)
Bump for offers.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
