I'm having a very lumpy idle, way more than before, I thought it was the nistune, but i just got back from the tuning with new haltech ecu. Is it better ? Yes, but still lumpy.
I also made serious lost of power than 2 yr ago ( about 15% less), my tuner think it could be that my Poncam is missing a tooth. But to be honest, I'm unsure what it means and.. what can I do to correct it ? do i need to start thinking about buying a new set of cams ?
thanks!
It means your cam timing is out 1 tooth.
Take off the front cover, rotate the engine to top dead center, cam gear marks should line up with rear cover marks exactly.
If the gears are out 180 degrees, rotate the engine one more revolution, 1 crank rotation = 180 degrees of cam rotation.
If its wrong, your out X amount of teeth, you need to loosen the cam belt and reposition your cams the right way.
2cents worth
- Type B's sound lumpy.
- Dyno results vary allot
however, if you have slipped a tooth then get it fixed now
if your tuner thought it had slipped a tooth then he shouldn't let you drive away without warning you of the potential consequences
That's true.
But type b are hardly high lift or large overlap.
Exactly, I dont consider these camshafts too aggressive, not to mention, I'v ebeen runing these for 3 summers now. so I know how they should sound.. i just always thought it was my tune with nistune who wasnt good hence why i went with the haltech.
So basicly.. if it's off, it's not like I have to buy a new set of camshaft or go for a ''head'' rebuilt ?
Type bs are lumpy enough though if your used to stock idle anyway
2cents worth
I have great respect for my tuner but he is not a mechanic ( nor I am, I believe in '' if you don't know what to do, don't try and do it, but that doesnt means I don't have the right to understand whats going on with my car :) ) and i left the dyno at 2h am, so at this point we couldn't diagnotic the problem. The car run great with the new tune, it just that it don't make the low-end power i was used to and the top-end theres a lost of 75 whp, but mid-range sound ''about right'' compared to last year tune.
For what its worth, I have type B's and a haltech (on a rb28).
After a tune, I have idles which can be described as uh, REAL LUMPY. I mean, car-shakingly lumpy. In every instance it was actually due to it simply running very lean on idle (~17:1 AFR). I was able to add a little to get this to 14.7-15:1 and the lumpiness effectively disappeared.
If all that happened was you got your tune, it may simply be a bit lean at idle.
That's interesting to me, cheers
I run type B's and Haltech PnP on my 26 and it's also noticeably lumpier at idle
- thanks will ask my tuner next time :thumbsup:
I don't think we can compare a 25 to a 26 because of vct.
If you activate vct at idle the 25 will also be heaps lumpy.
Compression test came out to 145-150-155-160-160 so its OK and was rebuilt less than 15k kms.
My mechanic did the timing test and here's the result: Exhaust is spot on. However intake was a bit less than a teeth.. maybe 80% of a teeth. I was told.. if it would be off, BOTH cam should be, not just one.
whats your take on this ?
If the crank pulley was off then of course both cams would be off. But surely it's pretty obvious that only one cam could still have been one tooth out.
WTF is 80% of a tooth?
Why isn't he talking in degrees? Did he even use a degree wheel or just eyeball?
we used eyeball since we were in a driveway. while the exhaust was 100% spot on, the intake was a bit off.
Ok. I misunderstood when you said "mechanic did the timing test"
As the 100 percent correct way to check is with a degree wheel and dial indicator . I assumed that's what the mechanic did.
Are they adjustable gears?
yup tomei's one. I will be bringing the car at the shop next year but i wanted to do some backyard testing to have a ''feel'' of whats going on with my car.
Edited by cobrAA
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
