Just wondering if anyone with past experience or has some tuning knowledge could give me their thoughts.
Would there be much advantage/gain vs cost by fitting a power fc or getting ecu nistuned on an R33 gtr that's virtually stock apart from 3"front pipe back exhaust and raising the boost (stock turbos)
If so, compared to completely stock setup, what sort of power increase/benefits would I be likely to see with...
*removal of boost restrictor, exhaust and either of these ecu's
*removal of boost restrictor, exhaust keeping factory ecu?
Thanks guys
HUGE ADVANTAGE not only to power, but also your wallet :)
stock vs nistune 32 33 & 34 You should see a gain of 50-100k's per tank when cruising. If you're travelling around 500k's per week you would make back your money within 6 months easily.
Yours being a gtr, you probably don't do too many k's. So it's not much of a worry.
But power gain i know for the above and min mods you could expect anything up to 40rwkw
Def worth it for sure.
I gained approx 50kw at the wheels after going from the stock R34 ECU to Power FC (now at 260AWKW give or take).
Fuel consumption, meh about the same as stock, slightly better on cruise (about 13 L per 100km)
Did you have to get it tuned also or was it just a plug and play with a default map?
Interesting question livewire, I'm trying to figure out an ECU path as well without going crazy with mods.
Edited by Sovereign337
Yes, had to get it tuned.
In practise, yes it is plug and play, I.E you can simply plug it in and drive away, BUT you would be stupid to boost it with the stock Power FC map... Apexi run some stupid high timing from default.
Not knowing your future power goals for the vehicle, I'd say stick with your stock ecu.
The only reason to upgrade the ecu is when chasing hp.
As for fuel savings when driving a GTR ????
I'd have to be the steadiest GTR driver on the road, highway cruising I get 10L per100 consistently.
Stock ecu and the Rb26, I'm never going to see fuel usage down in single digits.
The GTSt used to do 9 to 9.5 despite having a lot more hp on tap, the Rb25 with VVT is simply more economical at cruising speeds.
If you've got a heavy foot there's no miracles, economy is all about driving style.
A PFc will set you back around $800 and much the same again for the tune.
You'll never see that $1600+ returned in fuel savings, so forget that argument.
But if your plan on hp upgrades, money doesn't come into the equation, it all disappears.
  • Like 1
  • 4 weeks later...
I have a nistune but the closest tuner is 1500km. There is someone here that is comfortable with power fc, what would it take for him to modify my nistune to suit new set up? Or should I just use a power fc? I'd prefer to stick with the nistune since it has knock control and there can be up to 25c temp difference between summer and winter here.
Current tune is for n1 turbos, intake, exhaust and 15psi. I would like to install 680cc injectors and 16-18psi on nismo 0.60/0.64 turbos.
Cheers if anyone is able to help out
i would recommend if you have some spare coin to get the tuning tools you'd need and learn to do it yourself. follow some of the courses over at www.learntotune.com . at that distance you'd spend that much money in travel... I assume running nistune you are still running MAF's if so these should handle your temperature change...but running higher boost will put you in a different and possibly untuned area of your map....
And yes, still runnings mafs
But if it's just a matter of downloading the software and live tuning via consult or other cable I'm more than happy to get my buddy with Pfc experience to tweak it for me
nistune vs powerfc is 6 in 1 half a doz in the other....you need the tools first..... for nistune you need the cable and software (which is licensed to the nistune serial i believe) the Powerfc will need either the Power Excel software (crap to get) or the FC datalogit.
after that you need a way to measure Air fuel ratio and to listen to knock levels (detonation)
the powerfc will still show you what the factory sensors are picking up....if you are getting knock you will most likely have to reduce timing.
a dyno is still more accurate for tuning but these tools will get you in the ball park and most of the way there....fuel mapping first then ignition timing.
Might have to run with the power fc. I have access to data logit and the fella here with it has tuned his so mine shouldn't be too hard for him.
Was kinda hoping to stay with the Nistune, but if the license to tune it doesn't out way the advantages of having it then so be it.
Yep. Exactly as Badgaz said.
Something to condsider though is the factory knock sensors are old and probably crapped out. I certainly wouldnt rely on them.
A benefit of Nistune is it looks stock, and retains all of the nice things the stock ecu does (cold start etc)
yep thats pretty much where i started...i have a powerfc in my r33 and my wifes r32 gtr. feel free to flick me your maps/logs if you want another eye cast over them, i have a datalogit also.
Ben c34 I'm not too fussed on looks. You won't get your ass dragged through hell for having a power fc out here. Hell, it just cost me $125 for the inspections and certification to put the rb26 into my 180sx
  • Like 1
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
