Sup folks?
I'm having a garage sale, need to clear these parts that I won't have use for it.
No photos for time being, will take some and upload in coming days.
Price is negotiable.
1; K-sport 8 piston brake kit, 330mm. Rotors, calipers and pads are in good condition, to suit cars with 5x114.3. Caliper colour is black. Asking $1,200.
2; Set of 4 Super Advan RA3-DT in 17x9.5 +19, comes with nuts and internal drive socket. Tyres are 235/45/17 but to be honest, they're somewhat f**ked but good for rolling around in, would recommend new tyres. Asking $700.
3; Full set of Tein Driving master type flex, to suit r33 gtst and r34 gt (eyelet rear) done roughly 25-30,000km no leaks or knocks or anything. Asking $1,200.
4; Set of 6 Superspark coilpacks to suit RB25DET series 2 and BNR34 RB26DETT, used to diagnose a problem and the problem was inlet leak. Asking $300.
5; Pair of Nismo AFM, bought it with airbox for my GTR. No broken tabs, no broken mesh. Asking $500.
6; Set of standard coilpacks to suit RB20DET, S1 RB25DET and R32/33 RB26DETT, in working condition prior removal. Asking $100.
7; Pair of nismo seatbelt pads. In good condition. Asking $50.
8; Pair of Kaiken 6000K HID ballsat and globes, in working condition prior removal for RWC. Asking $100.
9; Pair of standard R33 GTR turbos, in working condition. Upgraded to -9s. Asking $150.
Have assorted items such as standard R33 GTR castor rods, upper front arms, tie rod and ends, HICAS unit with tie rods, and R34 GTT hicas unit. No idea of price but let's say $50 for pair of each. Don't PM asking if I have anything else.
Items location in Melbourne, Northern Suburbs - can post some items, some would require courier due to size/weight.
Again, prices are negotiable within reason, don't be afraid to PM me to enquire.
Cheers
Grant
https://www.sau.com.au/forums/topic/444459-grants-garage-sale-2014-edition/
PICTURE TIME COZ WE ALL LOVE PICTURES!!!!!
Nismo Shoulder pads
Kaiken HID kit
K-sport 8 piston brake kit - with doglegs to suit R33 GTST, may fit others, check with K-sport.
RA3-DT's
Standard coilpacks
Nismo AFM
Tein coilovers
Apexi intercooler and piping
There you go folks, as usual, I'll entertain reasonable offers, can help with postage at your cost. Help me putting them into good use, that means you buy!
:D
How much for the apexi FMIC and piping? Can't see it in your first post... ffffannnquuuuuu :yucky:
Oops, haven't list them. My bad!
Asking $450 for the whole she-bang - FMIC, piping, pod (engine bay pipe won't clear airbox in both 33/34. You can use standard in bay piping with the FMIC).
They're Apexi Delta Fin to suit R33 gtst and R34 GTT.
Yo peeps!
UPDATE:
Nismo AFM's SOLD and posted!
Everything else still available and as usual, will entertain reasonable offers.
You buy!
K-sport brakes is SOLD!
Everything bar brakes and afm is available an will take reasonable offers, these got to go, I've no use for them!
PRICE ADJUSTMENT TIME.
Sup folks?
1; K-sport 8 piston brake kit, 330mm. Rotors, calipers and pads are in good condition, to suit cars with 5x114.3. Caliper colour is black. SOLD.
3; Full set of Tein Driving master type flex, to suit r33 gtst and r34 gt (eyelet rear) done roughly 25-30,000km no leaks or knocks or anything. Asking $1,100.
4; Set of 6 Superspark coilpacks to suit RB25DET series 2 and BNR34 RB26DETT, used to diagnose a problem and the problem was inlet leak. Asking $250.
5; Pair of Nismo AFM, bought it with airbox for my GTR. No broken tabs, no broken mesh. SOLD
6; Set of standard coilpacks to suit RB20DET, S1 RB25DET and R32/33 RB26DETT, in working condition prior removal. Asking $90.
7; Pair of nismo seatbelt pads. In good condition. Asking $40.
8; Pair of Kaiken 6000K HID ballsat and globes, in working condition prior removal for RWC. Asking $90.
9; Pair of standard R33 GTR turbos, in working condition. Upgraded to -9s. Asking $100.
Have assorted items such as standard R33 GTR castor rods, upper front arms, tie rod and ends, HICAS unit with tie rods, and R34 GTT hicas unit. No idea of price but let's say $25 for pair of each. Don't PM asking if I have anything else.
Cheers
Grant
YOU BUY!!!!!!!!!
Kthnxbai
Advan RA3-DT is SOLD!
Will look into any offers for available items as usual, help me get rid of them! I've no use for them!
Nismo seatbelt pads are SOLD!
Still got;
Tein type flex.
Apexi delta fun fmic.
Stock coilpacks.
Super spark coilpacks.
Kaiken hid kit.
Standard turbos.
I'm sure I've forgotten what else (at work at the time of writing).
As usual, will entertain reasonable offers cos y'all know why I'm selling them.
Cheers
Grant
Price adjustment time!
Still got;
Tein type flex. $850!
Apexi delta fun fmic. $300!
Stock coilpacks. $50!
Super spark coilpacks. $150!
Kaiken hid kit. $50!
Standard turbos. $50!
You buy!
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
