Ok I only just got this R34 about two months ago There are posts on here from the last owners and what they did to the car as we'll I'm looking to do some more work to it like high mount turbo set up and intake manifold 1000cc injetors and fuel rail looking at getting it tuned on e85 as we'll I'm going for the 500hp mark and info on what I should do would be grate the car has a YouTube video under HPI R34 from stock to 11sec it is Former high performance imports magazine project car, many DVD and magazine feature articles. All work was carried out by Croydon Racing Developments.
Bodywork
*Fresh black respray
*Z Tune body kit including GTR front bar
*Carbon fibre boot lid
*Carbon fibre bonnet painted black
*Lowered
*JDM Decals
Engine
*RB25DET NEO
*146,000kms
*HKS internally gated turbo upgrade
*Twin entry front mount intercooler
*Split fire coil packs
*APEXI power FC
*Pod Filter
*4 Stage boost settings
*Fuel pump upgrade
*Blitz electronic boost controller
*Blitz RSM
*Complete turbo back exhaust
*Higher flowing cat
*Titanium tipped REGU cat back exhaust
Gearbox
*5 speed
*ORC super single clutch
Suspension
*White line sway bars
*Hicks lock bar
*Aftermarket shocks and springs
Wheels
*VARRESTOENS 18x9 +30 front
*VARRESTOENS 18x10.5 +30 rear
*Near New Tyres 265/285
Interior
*Omori gauges in factory gauge slots
*BLITZ RSM and EBC
*RECARO millennium bucket seats up front
*Very clean interior for its age
*Fusion front and rear speakers
*Fusion 10inch active subwoofer/amp
*Fusion USB/SD/Iphone/Bluetooth Head unit
Brakes
*Slotted disk rotors
Power
*212rwkw on 12psi
*296rwkw on 20psi/1.4bar
*500+ Hp @ Crank
*Ran a 11.9@Eastern Creek
  • Like 1
https://www.sau.com.au/forums/topic/444479-hpi-r34-gtt-skyline-aka-hpi34t/
The car is back to all black now and all the stickers where removed and tail lights got changed as we'll the is some photos in there from when the last owners had it as we'll number plates have been changed when the rego was changed over to queensland
Yeah Im not a fan of the stickers I'm not to shore about the trail lights thinking about getting the smoked tail lights to much Crome for me lol I'm also going to be working under to hood soon as we'll going to try and get it up on 500hp that's what I'm going for how much did you end up selling the car for when you had it
Edited by Luke William Thomas
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
