Hey folks! Tyrone here; up for sale is my 'rolling shell', R33 GTST Series 1. Chassis has 13xxxxKM. The pride and joy can still be registered, and was last registered in the ACT.
What's included in the sale:
(Please be aware that I do not wish to part out the car at all - it will be sold as a complete package)
Basically a complete car; all engine accessories such as power steering pump and alternator are in excellent working order and included. Also comes with Nismo 1 way differential. No accident history, good panels with your usual stone chip here and there.
Underside of the front spoiler looks a little rough cosmetically, however structurally it is completely sound, as it is not fibreglass, but OEM spec plastic.
Interior of the car is in excellent condition. Dash and doors are also in good condition. All electrics still work, however the common problem with the drivers side electric window switches was creeping up. Window glass is in fantastic condition with no cracks or stone chips, and are currently filmed with professionally installed window tint. These are a TOUCH too dark for the law, but I've honestly never had an issue with it, and I was pulled over plenty (the local constabulary is quite tough on performance cars, but they're still nice enough to talk to, even when they're giving the car a once-over).
Engine will be included with the sale. Spun a bearing due to oil issues (aftermarket oil cooler leaked like a hose during a spirited drive); the block is still in good condition, so much so that it was going to be reused in the build if an RB26 couldn't be sourced (which is basically what happened).
The head suffered some minor damage due to piston contact, however my builder (Peter @ Advan) has mentioned that it is quite repairable. Splitfire coil packs. Walbro fuel pump (unsure of exact specification - I believe it is the 255lph variant - if it helps, I was able to run 262rwkw very comfortably). A new oil and water pump will be required however, and are not included as 'running' gear.
A spare RB25DET head will also be included. It was bought second hand from a member here as a 'drop on and drive' part, however they failed to mention that the valve seats and clearances are buggered. Whether or not someone could use the head after a bit of work, is up to them. I also have spare cam caps and other bits and pieces that will be thrown in, they might come in handy.
Driveshaft and gearbox included. No issues with either of these - gearbox was great to change and still felt 'tight', however there are spring kits that can be installed to increase shifting feel even further. Exedy heavy duty clutch will be included, still plenty of meat left, had no slippage when car was running.
She sits on Whiteline springs front and rear, Bilstein shocks front and rear, with Whiteline sway bars front and rear, and also Whiteline castor and camber bushes all round. Brake upgrades include DBA 4000 slotted rotors front and rear with ADR braided lines. HICAS lock bar fitted.
Car comes fitted with R32 GTR rims with rubber. Spare set of R32 GTR rims will also be included, which have rubber (however most of these are not in a road worthy state of wear.)
Also included is a Vulture Motorsports front facing plenum, Greddy style. Condition is 'new used', has been taken out of packaging as cardboard box was damaged during transport, but never fitted or even test fitted. All hoses, fittings, bolts, nuts, hose clamps, and zip ties required to install will be included. Comes with Vulture Motorsports 90mm throttle body. A 90mm-to-standard adaptor comes with it also.
Full Complete OEM gasket kit. Purchased through Kudos Motorsports.
Gates racing timing belt.
Tomei intake/exhaust cam gears (non-vct)
Hi-flowed injectors (about 800cc from memory)
ARP Head stud kit. (suit RB20DET/RB25DET inc. Neo 6 - info taken from Kudos website)
ARP Main stud kit. (suit RB25DET)
Timing belt bearing kit - NSK (Nissan OEM)
Front mount intercooler with all piping (not too big)
Clear cam gear cover (generic brand)
Might have to update and confirm with my builder, but the full exhaust should still be there to include with the car. It is 3 inches all the way, de-cat pipe through to a HKS Superdragger muffler. Custom fitted and welded by Racepace in Melbourne.
Also included is the car's folder, which is full of receipts going back to 2005. Reprinted owner's manual in English in fantastic condition goes along with it.
There are more than likely other things I have forgotten to mention, however I will update this listing with any other things when/if I come across them in boxes and at the workshop.
So there are the goodies.. Now for the not so good points:
The drivers seat bolster had wear when the car was purchased, however I never got around to fitting the bucket seats I wanted, so it was never repaired/changed.
Previously mentioned front spoiler is rough on the underside.
Differential clunks a bit on low speed turns/cornering/parking - I know this is a somewhat normal thing with these diffs, however some people may find it annoying.
Electric aerial doesn't work - it is a problem with the actual unit, not wiring. The 'belt' that drives it failed about a week before the engine shit itself, so didn't have a need to replace it at the time.
And that's about it. She has been kept in weather proof storage for the better part of 30 months, hence the genuine low KMs on the chassis. Car was used mainly on weekends and nights out, as I had a work vehicle while the Skyline was on the road. During this time it was kept garaged and washed once a week.
In the flesh, it really is a great car. Even now, it still gets compliments from friends and mechanics at the workshop. Straight body and chassis rails with amazing condition panels and excellent condition paint - in a great colour too, which makes it enjoyable to look at. (Some swirls can be seen if at the right angle, however a professional detailing with 'paint correction' will sort this out for you.) The combination of the colour of the paint, with dark tints and black rims, gives it a nice presence on the road, with that awesome 'sleeper' look.
Before buying Suzie, I didn't really have much love for the R33 shape. She changed all that, and now I love it.
Regrettably however it is not feasible for me to keep or complete the car, so with a heavy heart I have made the choice to sell it.
As it stands, I am looking for $4750. I am negotiable, but low ballers and ridiculous offers will be respectfully declined with reason. I am a genuine seller looking for a genuine buyer. Please no time wasters. If you have any questions or comments, please shoot them my way, as I'd be more than happy to answer them/respond to you.
Location is in Sydney. Prefer local or within a couple hundred KMs.
Contact me at dajae.sau@gmail.com or PM me on here. Will supply my phone number for those who are genuine and interested, as I'm not looking to have my phone number plastered all over the interwebz :)
Thanks for taking the time to read, and have a good one! :)
PS: Here are some pictures of when it was still on the road. Apologies for not having current ones during the creation of this advertisement; I will be making my way down to the workshop this week to get plenty of updated pictures. If anyone has any requests for 'up close and detailed' pictures (of the car that is ;) ), then please leave a comment and I'll do my absolute best to accommodate.
http://postimg.org/image/5vzeyi0pj/
http://postimg.org/image/jodtu4rh3/
Sorry guys, forgot to mention... There is no turbo included with the sale.
Really quite sad to have to sell, as she was my first Skyline.. It's been an awesome love affair but it must come to an end.. Finish my project by dropping in an engine, or rebuilding the current one, and have a great condition Skyline with a tough engine for a fraction of the price.
More pictures coming soon... Negotiable, make me an offer :)
  • 3 weeks later...
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
