Being a new R32 GTS-T owner (as well as it being my first turbo car). I have heard people talking about warming up & cooling down the turbo...
Being new to turbo cars, I just want to make shoure I am not going to stuff it up.
My R32 is stock (except exhust) and I was wondering about the do's & dont's with warming up & colling down with turbos. With a stock setup is it a big deal or is it when you have high performace parts on the car?
Reece
https://www.sau.com.au/forums/topic/44449-warming-up-cooling-down-turbos/
when you drive a turbo car hard under boost it gets extremly hot ie the whole rear part of the turbo glows red so you should let i cool down when you have thrashed it also driving it quitely for 2 mins before turning it off will suffice.
meggala
this is an idea of how hot they get disreguard the writing.
drbanner.jpgs
For the past ~2.5years of owning my 32 i've never really warmed it up or cooled it down.
Warming up.
It idles for the amount of time it takes for me to put on my seat belt, put the cd players face on & put my wallet in the glovebox.
I then drive it real easy until it is at operating temp. I then drive it normally until ~10km's later from initial startup. It takes around 1-2km's to reach operating temp.
Only after then do I give it some stick if I am going to.
Cooling down.
I havn't got a turbo timer and don't really see the need for one, especially when you consider the possible insurance and defect hassles.
Before you turn the car off just take it easy for the last few km's.
Then let it idle for the amount of time it takes to grab your wallet, take the seat belt off etc.
If I have really been giving it a heap (can smell the brakes etc still) I let it idle for 2 or so mins.
General driving with the odd little bit of stick I don't worry about cooling the car down, just make sure turning the car off is the last thing you do. This will give time for the turbo to spool down.
Only once I have turned the car off just after coming off boost. The nasty sound of the turbo spinning was enough for me to instantly start the car and wait a minute or so.
It seems the ol' turbo's being water cooled and oil cooled are quite tough items these days. I've been pumping quite a bit of boost through it for some time and it still hasn't broke. :) I don't race or give the car a hard time or do high speed high boost long stints.
Out of all my cars this 32 has been THE most reliable out of them all.
Driveline, diff, motor everything is tough, and thats comparing it to a VS V8 5speed that are 'supposed' to have tough gearbox's. Mine still broke within 6months, then the diff then the rear subframe and the list goes on. :D
I've got a $0 bodgy way to increase boost if your interested.
You have to be carefull though. :)
Elongate the wastegate actuator bracket bolt up holes. Then pull the wastegate actuator and bracket back tightening it up. (Pull the wastegate actuator towards the front of the engine) Then tighten up the two bolts.
You then need to take it for a drive and fine tune the adjustment so it doesn't over boost.
Thanks for the info, it has help to clear some things up for me.
Since I dont drive it hard (all that much) there isnt much i need to do. Except make shoure it has warmed up before driving it hard, andif I have been riving it hard to take it easy before I pull in the driveway.
Thanks again.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
