Hello fellow SAU'ers,
unfortunately my GTR will have to be put in to hibernation for 6-8 months as I'll be in between garages (building new house....)
So I am putting the car into storage for that period of time.
Any tips and advice for leaving the car to ensure it stays 'healthy' are appreciated.
In particular - can anyone suggest a good car cover ??
Cheers and Thanks
The Baron
There is a mob that do custom car covers, I've been meaning to enquire about one for an r32, they are fitted like the ones that come with ferraris I believe
Also some fuel saver like sta-bil in the tank to stop the fuel going bad. Trickle charger or d/c the battery.
There is a mob that do custom car covers, I've been meaning to enquire about one for an r32, they are fitted like the ones that come with ferraris I believe.
Covercraft...........
I have one of these for my ADM R32........... http://www.covercraft-pacificshop.com/carcovers/form_fit_indoor_covers.html
Cheers,
Bob.
You dont need to go too crazy like some do.
If its inside and dry, any car cover will work.
I had my Skyline parked up for 2 years when i left NZ for Perth temporarily. Was only driven by me once every 6-8 months.
All i did was disconnect battery, chocked the wheels with handbrake off, low fuel, and a cheap Repco car cover. (garaged)
Started first turn every time. Instant oil pressure. No trickle charging or anything.
The first stint i went as far as putting the stock rims back on to avoid flatspotting my good tires. But in the end i got lazy and just bumped up the tire pressure. Never had an issue with the RE002's that were on there.
Some people get overly paranoid. each to their own obviously. But you dont need to go absolutely crazy.
Do whatever makes you comfortable!
  • 2 months later...
Ensure the engine oil and gas tanks are cleared out before you put the car up into storage to avoid any potential freezing or hardening of the liquids. A car cover should also be mandatory even if you are already putting the car up in storage. Sometimes fine particles inside the unit itself can still be up for some exterior damage, though not so major of course.
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
