Ive just finished installing an avcr, but im stuck on the solenoid installation
Ive put up a picture can somone tell me if this is right, and where the Yellow line wire goes!?
It joins up to the pipe that goes to the BOV, do i just T this into the COM side of the avcr solenoid or block it off?
Ive fully removed the factory solenoid so its just left that hose there and i have no idea what to do with it
Thanks for the help!
https://www.sau.com.au/forums/topic/44453-help/
ok i see what u mean, but that means the Yellow hose on your car goes nowhere too
look down and see if you can see what he's done with it, standing over the front left guard its near where the actuator hose comes from just to the left
It (yellow hose) joins onto the metal pipe about 1.5inches thick that goes up the back of the engine bay and joins onto the Blow off valve
thanks heaps for all this buddy
https://www.sau.com.au/forums/topic/44453-help/#findComment-908885
Ahh ok ok i just found it in the diagram in the manual
i have to cap it or block it off
sweet :D
Did you connect the purple wire to Injector or RPM?
I want to montitor injector duty but only to see how they are going, then ill connect the purple wire to RPM
Also, it says in the initialisation i have to set the cylinders to 1 if ive used the purple wire to monitor injectors
Time to go do some on road testing/tuning :)
Thanks again
https://www.sau.com.au/forums/topic/44453-help/#findComment-908907
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
