I know there is a sensor that controls fuel on my rb26 according to temperature, does anyone know how I can test the one I have now, and where can I buy a new one.
I have a power fc and was also wondering if I can use that to see if the sensor is good or not.
Thanks.
https://www.sau.com.au/forums/topic/444541-looking-to-find-a-new-sensor/
Coolant temperature sensor. Do some googling for the expected resistance vs temperature. Test it in hot water on the stove with a thermometer (at one cold temperature and one hot temperature) and see if it lines up with the spec.
You can buy a new one from Nissan, eBay, about 30 trillion on-line retailers, etc.
Edited by GTSBoy
Don't RB26s run an air temp sensor to measure how hot the air going into the engine is? I would put that one ahead of the coolant sensor.
Pretty sure you will find that would actually have far less of an effect on the fuel ratio.
Edit.
Actually I'm not sure the ecu even uses it.
Edited by Ben C34
I pulled my plugs and seem like its running rich. And at one point it was hard to start. Once started it runs fine. Looking at idle my afr gauge was around 12s. I would have to go into my power fc and manually pull fuel out to get it to read around 14s or less. Im still waiting on some parts to reach then ill test and tune things. I have a strong feeling that my temp sensor is acting up.
The ECU uses it, but as far as I can tell, not for anything in the day to day setting of mixtures or timing. I think it is only there to call a halt to proceedings if temperatures get way too hot.
i think it uses it to pull ign timing when inlet temps get too high....i'll double check though.
Edited by Badgaz
looks like it'll do both, however it is inj vs airT and boost. which i'm guessing might only be enabled if you have the PFC boost control kit. 50 degree airt = 0 60 degree airt = 3 degrees retard 70 degree airt = 5 degrees retard
i think i have this same problem with my wifes GTR...the temp never went over 75 on a night of logging and tuning which meant it was always getting slightly more fuel across the whole map.
Doesn't really matter what the PFC does with it....it matters what the factory ECU does with it. Which isn't much.
Face it, about the only Nissan engines that have the air temp sensor are the RB26 and the SR20. And the sensor is a big lumpy slow reacting piece of crap better suited to measuring coolant, so it's hardly going to be used for serious business. That's why we have air flow meters.
  • Like 1
its much colder here in NZ. it was about 8 degrees that night. it matters to me what the PFC does to it....and i don't care what the Factory ECU does, but i'll find out anyway...and i think the OP has a PFC. Just checked my logs and water temp was sitting 75 degrees to 77 the whole time...the IAT was showing 30 degrees....
Badgaz, GTSBoy was referring to the air temp sensor, not the coolant temp.
It sounds like your wife's car might have a low temp thermostat installed. Which sucks. Alternatively you could look online and fine the resistance at various temps for the coolant temp sensor and test it with a meter. I would do that before pulling out the thermostat.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
