Hello i was pumping up my tyre and i noticed what looked like black paint or like someone has drawn a line with a black permanent marker on the chrome lip of my rim, it is shiny and black does not feel like a scratch cos if i run my finger over it i carnt feel it at all but it looks like a black mark on the chrome lip, the lip is also slightly dipped in so if i got too close to something the scratch would be on the bit that sticks out more and not the bit that dips in, i tried to clean it with solvents and then with polish but nothing removes it. And i just dont understand why it is black for cos it is on chrome and as i said you carnt feel it at all running your finger over it, so does anyone know why it is like this? and how do i fix it
https://www.sau.com.au/forums/topic/444581-lenso-rims-scratch/
I'd say its painted chrome which is usually painted over a black base ,in which case the paint has scuffed through....I have a wheel the same, is painted black chrome...you can't really fix it though you could try repaint the area, it might come up ok.
btw the way carnt is not a word, the word is Can't , its an abbreviation for can not ;)
That "cannot" be right ;)
man I actually checked that, well by checked i mean I asked the wife cause I couldn't rememeber, is cannot 1 or 2 words...she said 2, she's the one who reads books all the time, so I took her word for it..I just read car forums and most people here have worse grandma than me...
but for the sake of clarity
http://www.dailywritingtips.com/cannot-or-can-not/
we are both right ;)
Mick you are still wrong mate, back to school you go carnt!
lol and i now know what the black is, it bugged me on how it hot in the lip cos the lip is dipped in on the middle and i have worked it out, it is not paint that came off and black under it, someone had rubbed there tyre onto my rim and that is rubber transfer cos it can be scratched off with an abrasive and its chrome under it but no solvent will touch it at all for some reason, and using abrasive will take the clear coat off which im not worried about cos i have white stone chips all over the clear anyways so looks like i have to polish all the clear coat off all the chrome and thats a massive job
BA (hons) (usyd)...cannot :P
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
