Hello
I have read about putting rb25 turbos onto rb20's. One thing I cannot find a clear answer to is if the engine needs to be tuned to run it.
Is it ok to run a rb25 turbo on a r32 gts-t rb20 engine without a tune for a couple of months?
My mods I have are full turbo back 3inch exhaust with a sports cat and split turbo pipe, pod, and the return flow fmic.
I am going to put in a new aftermarket fuel pump such as a Walbro or Tomei.
The rb25 turbo that I have has the HKS actuator on it.
I live in Japan so not so hot as it is in Australia.
Will I be ok running the rb25 turbo on this set up?
Edited by yoshiii335
It will be fine, my 25 turbo has been running 16psi on the stock ecu for 2years now with no problems
Oh, youve been running 16psi? I thought they were not good over 1 bar before they run high risk of breaking?
What kind of response and power have you gotten without a tune?
Well without putting the car on a dyne before and after (and then why wouldn't you get a tune anyway?) you won't be able to tell apart from the seat of your pants.
You can run the turbo over 15psi but there's obviously a much higher chance of it falling apart. 12-14psi is usually what is considered safe.
Car made 130kw atw and now has 170kw atw, i have herd the same thing about not going over 1bar. I have been keeping an eye on it and there is no shaft play and not blowing any smoke, being a auto may help take some wear and tear of it though
The 1 bar limit is the apparent safe limit on an rb25.
On an rb20 one would assume you could run more boost, as it is shaft speed that destroys the turbine, not boost pressure.
O.P. is apparently using stock ecu so anything much higher than 1.0 bar (depending on weather conditions) will probably have it coughing and farting.
I fitted a 25 turbo on my 20 in the Rustia, used the 20 actuator and it went very well.
Added a bleed valve to increase boost and it didn't like it. So I left it at the stock 20 actuator boost but reading the signal after the cooler.
Obviously the 25 turbo is not working as hard to pump a given boost on the 20 as it was for that same boost on the 25.
A good cheap upgrade for a 20 in my opinion.
FWIW, I ran my sietbox 180SX (RB20DET) back in the day with a RB25DET turbo at 1bar on the stocker ECU.. went alright, until I got a CEFF1E remap (not sure if he is still around) and the car started to wake up
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
