Hello i have a problem with my rb25de neo. It's and auto but i genrally use the semi auto the drive but the problem is that after i get up to 3000rpm. In second gear then change to third and will have a spot where it drops right back down to like 2500 and after a second it picks back up again.To where it should be and it's 5 times as worse if the aircon is running and it will happen even if you change at 2000 rpm. Im totaly stuffed about it i got cam cover gaskets and new spark plugs recently.I thought i would ask on here first before i get my mech to look at it maybe a simple fix?.
Cheers!
https://www.sau.com.au/forums/topic/444597-flat-spots-in-rb25de-neo/
Had the same problem a few months ago
Took the intake pipes and vac lines off so the coilpacks could be changed, forgot to tighten up the clamps for the vac lines and they popped off/weren't sealed properly
I think I may still have failed one of the plugs when this happened as I can still feel a very slight miss around the 3k mark
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
