http://www.gumtree.com.au/s-ad/canley-heights/cars-vans-utes/1989-nissan-skyline-coupe-420kw-/1048279361
Hi,
Unfortunately, the time has come to say goodbye to my GTR. I have been building this car over the past year and a bit, but it is time to move on.
List of mods are as follows
Car has been tuned on E85 in April 2014 - 422KW @ wheels
Cp forged pistons
Tomei poncams type B
Acl gasket kit
Argo rods
Arp main studs
Arp head studs
Acl bearings
Nitto oil pump
Full reco head with baby cams
Custom made exhaust manifold (not eBay shit)
Garrett Gt35/40 with 60 mm turbo smart external waste gate
screamer
Greddy intake
BOSCH 2200 cc injectors
Power FC + remote
Sard fuel regulator
Greddy Turbo timer
Walbro aftermarket fuel pump
TIAL blowoff
Splitfire Coilpacks
****many more to list, jsut cant think of it all off the top of my head
Handling wise, I have Full set of HKS coilovers, will come with standard shocks and springs at the right price. Cusco front strut, also have after market rear strut. I also have a full set of ADVANS RG's which will come at the right price. I will also throw in a full set of standard r32 wheels.
the negatives - The body is not a show spec body, i do drive the car. But with that said, it still looks good, just a few minor scratches here and there, it is washed every week, even though it is only driven twice a week.
the interior - everything is there, the headunit however is not installed, but will come with the car. The only downside is the drivers seat has a tear, this is very common with r32 GTRs.
Please feel free to arrange to meet. i work weekdays and dont get back until 7pm. so weekdays would be the best, or late on weeknights. No test pilots untill deposit is taken.
Price and price conditions: $21500
Pictures: located in link
Contact Details: 0426876899 - dan
##please note number plate is not included in sale
https://www.sau.com.au/forums/topic/444615-r32-gtr-21500/
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
    • My answer would be, that depends. If it's something that can be grumpy to start, runs a bit rich, and is likely an expensive engine, then yes, I would. But there's a few reasons why. Sumps aren't really sealed, there is airways to them, so it is technically open to moisture. Secondly, if as mentioned it has been started, and it's a fuelled up, I'd dump it, as chances are, fuel is in the oil. Next to that comes, how much use had said oil seen before it was parked up. IE, how much carbon, and potentially fuel/water did get in there while it was being used, and has now been allowed to sit, and slowly come together? For the most part, if it's just been something like a road car, stock engine, nothing wild, f**king send it if it's not near oil change spec.
    • I forgot to say Mark, you know how if you lack sleep, we get Grumpy Mark? When I lack sleep I'm Grumpy Matt. We must be the GrumpMa's!
