Hey Guys,
For the last 2 years I've been looking around for an R33 s2 mspec front lip, about a year a go I bought a front bar that had been in an accident with ~60% of the lip intact, it's missing a section that wraps around the passenger side. I'd like to have a crack at repairing the current lip or replicating a whole new one, where should I start? I've never done fiberglassing or molding.
I assume taking a mold of the drivers side would be required, then somehow 'flip' it so it's a mirror image for the passenger side? I'm not sure how I would go about that.
https://www.sau.com.au/forums/topic/444625-re-building-a-front-lip/
You can actually ^ Not to make a mould, but given that piece of the lip is symmetrical, one can take a skin of the one side and flip it around to fit the other side. Works for things that are symmetrical and don't taper in a certain direction.
If you haven't done fibreglassing before then I'd advise playing around with it before attempting to fix your bumper. You might be better off trying to find another one, but have a play with some fibreglass and resin and see how you go. That said, this isn't the hardest of repairs. Nor is it easy to explain. One way to do it would be to cover the drivers side of the lip with clear packing tape (make sure it's the polythylene stuff), then use EPOXY (polyester shrinks and the styrene will attack your paint if it is exposed, nasty stuff) and woven fibreglass cloth to make a skin of each individual bit. Break it down into the bits that you can flip and fit into place on the passenger side. I'd estimate it is likely to be 3 pieces, the inner piece on the left that is partially cracked, the piece that runs along the bottom edge of the bumper, and the piece the sits on the side of the bumper. Get me? Then you can cut the lip off where it is cracked so it is square, and bond on your new pieces. Then feather them in using body filler, before spraying high build primer to fill the final low spots. Easy right?
There are quite alot of complex shapes there to flip im not sure it would be of benefit using a flip method...
Id say just get a better one, there is a heap there to recreate especially if you havnt done it before
Yes but you don't have to copy all of them. Just the ones that work, to give you a profile. Then you can fill the rest.
It's not the easiest job, but it's not super hard either. For a production item like this it's always going to be better to find another one though, unless you want to make it in carbon fibre ;)
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
