Up for sale is a R34GTT ECU with Nistune type 4 board installed which has a tune file on it from JEM- made 286rwkw at 18-16psi on Precision 5558 turbo ( which is almost identical in size to a Garrett GT3076R). Will go on stagea (RB25DET NEO) as well as they are essentially the same engine/ecu minus traction control.
So if you have a similar sized turbo and supporting mods, you can just plug in and drive away safely to your tuner for a touch-up tune which is cheap, generally $100-200. This includes re-sizing/scaling your injectors and afm in the software settings. A full tune only (like what this ECU has) will set you back $800-1000 at the usual recommended tuners.
Its in perfect working order and there is nothing wrong with it, I have just gone down a different path, chasing more power/ more features in an ecu.
Only $550 including registered post anywhere in Australia.
Ron 0416424446, or pick up from Parramatta NSW
I'm not interested, but to help sell it listing what injectors and afm it was tuned with would help.
Unfortunately the tune in an ecu isn't worth much second hand....
This Nistune was tuned with the Z32 afm and Siemens 630cc injectors.
As for how much the tune in an ecu is worth, you have the right to voice your opinion; I have seen many go for much more than this. A tuned ecu like this saves you a good amount of money in the long run as well, which could be used to get other go-fast gear.
  • Like 1
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
