Aftermarket ECU
Tebie
 Share
just wondering what aftermarket ecu's people have used in there skylines,
more specifically the R32's. ive heard of some owners using a-pexi systems, not sure which ones though. any help would be appreciated.
cheers
You should be able to use an R33 PFC with no problems (just remember to make sure the map is OK :) ). For some reason only the 32 and 33 PFC are interchangable; the R34 is different. Anyone know how/why?
Edit: A little birdie told me that Apexi has suspended PFC production, and will be stopping production completely for a range of cars; only particularly popular models will be continued, but a "revision two" or something is likely when production starts again. Also, PFCs will now only be sold with hand controllers (at a slightly reduced price).
LW.
The method they use to determine air pressure is different: you can read the epic battles over which is better by doing a search.
I think its got more to do with the tuners available in various states. In WA there is a good reason to go Wolf (since SST are the largest seller/tuner for them); in the eastern states I think the PFC might make more sense.
LW.
LW.
I AM NOT A FVKIN BIRDIE :( :(
Apex Engineering from the looks of it will be continuing their line. Apexi has ceased production of PowerFC's till the end of July when they restart production of revised models which will be sold in a bundle with a handcontroller at a lower price
I'd assume an R34 one is different due to it having VVT
Hi Tebie, what is the best solution for you depends on what your power target is, what mods you are going to make to get there, how much money you want to spend and whether you are going to do it all at once or spread out over time. With this info it is much easier to point you in the right direction. :(
BTW, the standard R32 ECU can be chipped and real time tuned for around $800.
The cheapest i could find a new Pfc for an R32 GTST was $1150 delivered, plus $420 for the hand controller.
If you are pretty good with wiring diagrams, im about 90% sure you could buy the much cheaper R33 Pfc (around $8** new) and fiddle with the harness to get the thing to work.
The few RB20 PFcs i have seen floating around 2nd hand are going for about $1200-1600 depending on the particular person and whether they come with hand controller... so neither option is exactly cheap and is :bs!: when you see how cheap it is for SR20 or RB25 owners to buy them. :(
I hope the new Hand controller isnt a "beauty item", as i just bought one of the old crappy / plasticy ones.... and for a little over $400 i want a nice ricey looking one, a bit like my AVCR... :(
PFC's for the R32's are fairly rare in AUS, I know of one place which asks around $1800.
If you are willing to wait you can order them from http://www.nengun.com/ and http://www.greenline.jp/ for around $1100. From memory they don't attract stamp duty but still attract the GST. So slap another 10% on top of that price.
I looked in to the Wolf3d and the only thing that let it down where I am is the lack of people able to tune it well and the lack of sequential Injection. Apart from that it is a good ecu.
the mods i want to do include:
600*300*76 FMIC
hi-flow turbo or upgrade the turbo
3" inch exhuast
GTR injectors and fuel pump
pod air filter
and i was probably do it all within 5-6 months
depending on pricing and availability for some parts.
R33 and R32 are basicly the same pinout and it easy to use a 33 in a 32.R34are totally different plug etc.
Wolf have MAP or MAF. Wolf use the same ECU for 33 and 32s only the vvt is not used in the 32 and u can run the wiring to a boost solinoid for boost control as in the 33.
 Share
    • So I've been working on the car a fair bit, doing a lot of little things. Preparing some projects for this winter, as I'm taking 13 weeks off very soon for parental leave. Have my second kid on the way and he's due any week now. I'll need something to do while he's sleeping. I also usually take the car off the road in about a month and a half, until sometime around the end of March.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
    • Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not  on the street
    • i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
    • Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
