Apexi Pen Turbo timer $5
RB26 Ross Tuffbond alternator pulley, standard replacement (no under/over drive) suits 17mm shaft $20
OS Giken 5th gear set. NOT A FULL GEARSET, just 5th gear. $200 ONO
R32 GTR Parts:
KN airfilter, identical to a Ryco A360 filter. includes some oil. $20
http://www.rycofilters.com.au/catalogue/part/make/HOLDEN/model/COMMODORE/series//part/A360
solid clutch booster replacement with pushrod, would suit a track car. $50
front sump, complete except no diff cover $50
ignitor box $10
coil packs and brackets $10
under dash air con box $10
air con compressor $10
knock sensors $10
RB26 inlet manifold. Might be missing a couple of nuts and bolts. came off a car that wasn't running. Would suit full rebuild. $50
power steering pump $10
Most of this will go to the tip if it doesn't sell.
Pickup from Quakers Hill, NSW and items can be posted.
No aero parts.
air con compressor
knock sensors
inlet manifold
sump
pwr steer pump
ignitor
Sold to Livicuru pending payment
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
